September 21, 2011, 19:55 |
nu in cavity example
Bob Beattie
Rep Power: 15 |
Hi everyone,
Just to warn you, I'm a complete CFD noob. Looking over transportProperties file in the cavity example, what do the seven values within the square brackets represent in "nu [ 0 2 -1 0 0 0 0 ] 0.01;" ? I see there are also seven-value 'dimensions' entries in the 0/U and 0/P files. Are these related to the nu entry above ? Thanks, Bob. |
September 22, 2011, 08:14 |
Disabled
Rep Power: 15 |
Hey Bob
The answer is in section 2.1.1.3 "Physical properties" of the user guide. http://www.openfoam.com/docs/user/cavity.php These are the physical units (m^2 / sec) |
September 22, 2011, 08:46 |
Bob Beattie
Rep Power: 15 |
No, section 2.1.1.3 only details the kinematic viscosity value.
My question was, with the line "nu [ a b c d e f g ] 0.01", what does a -> g mean ? I do appreciate your help though, so please bear with me. Bob. |
September 22, 2011, 09:05 |
Bob Beattie
Rep Power: 15 |
Found it ! Under section 4.2.6
Classic case of RTFM ! |
Urgent: Unsteady 3-D supersonic cavity flow | Min-Sung Kang | FLUENT | 3 | April 6, 2014 10:50 |
is there any parallel code for the famous Lid Driven Cavity flow? | gholamghar | Main CFD Forum | 0 | August 1, 2010 02:55 |
cavity in flat plate and drag prediction | Far | FLUENT | 0 | May 19, 2010 15:47 |
drag of flat plate with cavity | Far | FLUENT | 0 | May 18, 2010 05:57 |
axisymmetric model of two rotating disks cavity | liaolingling | FLUENT | 0 | April 27, 2005 05:24 |
