Measuring wall shear stress in bend pipe
Like Tree38Likes
Old   February 13, 2012, 20:02
Guifan Li
liguifan is on a distinguished road
Can you post your bifurcation geometry as well as how you measure the WSS?
Originally Posted by itsme_kit View Post
Hi
Can you tell me how to measure the wall shear stress?
I'm confused why my wall shear stress is zero and only a tiny part in inlet is non-zero
I am modelling a 3D laminar straight pipe flow by using star ccm
liguifan is offline   Reply With Quote
Old   February 14, 2012, 11:24
itsme_kit is on a distinguished road
I uploaded some plots and you can have a look
I'm not sure how to measure WSS
I just created a scalar plot and then selected wall in parts and WSS in function
Appreciate any useful suggestion
Thanks
itsme_kit is offline   Reply With Quote
Old   February 14, 2012, 19:50
Guifan Li
I think there is tool under filter is plot over intersection curve.
1) In property inspection field, choose the wall object (whoever the name you named it).
2) Use "Clip" to get rid of the part you do not want to measure.
3) Use "Plot over intersection curve" to plot the wall shear stress over the line which is the intersection of a plane and the wall.
Thanks
Old   August 13, 2012, 10:11
Tian Coulsting
TianC is on a distinguished road
Hi guys,
Is there any way that you can output the wall shear stress at every calculated time step (to use this as a measure of convergence to a steady state)? I would like to incorporate it into the solver but not quite sure what the script would look like. Any help would be greatly appreciated.
Cheers,
Tian
TianC is offline   Reply With Quote
Old   August 13, 2012, 10:17
Amir's Avatar
Amir
Amir is on a distinguished road
Try this:
solve->monitor->surface .... wall fluxes (wall shear stress)
Bests,
amuzeshi likes this.
Amir
Amir is offline   Reply With Quote
Old   August 13, 2012, 14:42
Tian Coulsting
Originally Posted by Amir View Post
Try this:
Bests,
Sorry, where does this go? In the solver.C file? (I have made a new solver called mypisoFoam) I have been trying to incorporate an average wall shear stress calculator over the top surface of my simulation. I have added this to mypisoFoam.C:
// Print out average wall shear stress over topSurface
// // find the identification number (e.g. label) for our boundary of interest.
label topSurfacePatch = mesh.boundaryMesh().findPatchID("topSurface");
// if we don't have such a patch, warn the user
if (topSurfacePatch==-1)
Info << "Failure to find patch named topSurface for average wall shear stress calc."
<< endl;
else // calculate the result and do output
// the sum operator implicity loops over the boundary faces and stores the result in avgWSS
scalar avgWSS = 0.0;
avgWSS = sum(wallShearStress.boundaryField()[topSurfacePatch]);
reduce(avgWSS,sumOp<scalar>());
Info << "Monitor: at Time = " << runTime.timeName() << " -- Average wall shear stress over top surface= " << avgWSS <<" [kg/(m*s^2)] " ;
When compiling with wmake, the following message appears:
Making dependency list for source file mypisoFoam1.C
SOURCE=mypisoFoam1.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/hpcwarwick/openfoam/2.1.0/OpenFOAM-2.1.0/src/turbulenceModels/incompressible/turbulenceModel -I/hpcwarwick/openfoam/2.1.0/OpenFOAM-2.1.0/src/transportModels -I/hpcwarwick/openfoam/2.1.0/OpenFOAM-2.1.0/src/transportModels/incompressible/singlePhaseTransportModel -I/hpcwarwick/openfoam/2.1.0/OpenFOAM-2.1.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/hpcwarwick/openfoam/2.1.0/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude -I/hpcwarwick/openfoam/2.1.0/OpenFOAM-2.1.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/mypisoFoam1.o
mypisoFoam1.C: In function ‘int main(int, char**)’:
mypisoFoam1.C:175: error: ‘wallShearStress’ was not declared in this scope
/hpcwarwick/openfoam/2.1.0/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/readPISOControls.H:3: warning: unused variable ‘nOuterCorr’
/hpcwarwick/openfoam/2.1.0/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/readPISOControls.H:15: warning: unused variable ‘transonic’
make: *** [Make/linux64GccDPOpt/mypisoFoam1.o] Error 1
The problem appears to be that it can't find wallShearStress as a variable. How do I make it calculate/read this?
Cheers
Tian
Old   August 13, 2012, 15:37
Amir's Avatar
Amir
Oh, sorry about previous post, that was a forum conflict!
But in openFoam it seems that the original utility compute wall traction instead of wall shear stress and I posted the revised form you can easily embed it in your solver and assess its changing. (note that it's a revised utility now which can be used in this form as a utility or you can put in your desired code with few manipulation)
see the attachment ...
(the error of your code is that you haven't defined wall shear stress yet)
epi_c likes this.
Amir
Old   August 13, 2012, 19:04
Tian Coulsting
Thanks a lot for your reply Amir. Does the old wallShearStress function not actually give wall shear stress then? In your utility it requires a tau file in the 0 directory and therefore gives the resulting error message:
--> FOAM FATAL IO ERROR:
cannot find file
file: /gpfs/home/eng/mauiie/OpenFOAM/mauiie-2.1.0/run/project/cavity2D/solverTest/0/tau at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
Is this a file used by the RAS solvers? It appears that this utility is designed for RAS not LES. With the old utility it was possible to make some alterations to the script (mainly changing RAS to LES wherever it occurred) and the utility would just as well with an LES case. Is this possible also with this solver?
Also, how would you embed the function into the solver? Would you simply copy and paste it in? Or would you do something more a long the lines I started with?
Sorry for all the questions, I am a bit new to OpenFOAM. Please bear with me
Old   August 14, 2012, 07:26
Amir's Avatar
Amir
No, as I said it leads to wall traction instead of wall shear stress. (you can easily check the formulation)
cannot find file
FOAM exiting
Of course it is! the tau parameter depends on your model. (actually I prepared it for viscoelastic solver where the tau parameter exists but for general cases you have to set its formulation in your code)
It's the general from and you can set it for any solver appropriately.
Sure, I did it for a simple code which uses moving reference frame; but note that according to the code, there must be initializing files additional to the current one in 0 folder where you can change them according to your purpose from IOobject control .... (see the attachment) it's just a template; you can change the IOobject.
Haier and TianC like this.
Amir
Old   August 15, 2012, 08:23
Tian Coulsting
Thank you again for your help so far.
I've managed to incorporate the wall shear stress into my solver now (after some modifications to createFields.H).
Ideally what I want is to output an average of wall shear stress over the top surface of my simulation into a log file (for every deltaT). I have put this script in at the end of my script:
<< endl;
avgWSS = sum(mag(shear.boundaryField()[topSurfacePatch]));
It is now outputting the sum of over all of that patch. The only thing I need to know is how to say divide by the total number of points on that face??(this is because I need the average not the sum)
Cheers
Tian
Old   August 15, 2012, 08:31
Tian Coulsting
Also, the script that gives a line break would be very useful
Old   August 15, 2012, 09:55
Amir's Avatar
Amir
Have you taken a look over patchAverage utility? (postProcessing->patch->patchAverage)
As you can see; you'll need to compute patch area there (not the numbers!):
scalar area = gSum(mesh.magSf().boundaryField()[patchI]);
use endl (see the above utility (patchAverage))
Bests,
Amir
Old   August 15, 2012, 10:53
Tian Coulsting
Thank you again Amir, your help is greatly appreciated.
Why should it be over the patch area rather than the number of points on that patch? Since the shear utility outputs a vector at every point on the patch, surely the more points you have (i.e. a finer resolution of mesh) the greater the sum of these vectors will be. So it is by dividing by the number of points that you would achieve the average.
Cheers,
Tian
Old   August 15, 2012, 11:47
Amir's Avatar
Amir
The resolution is not the concern but the mesh grading is. If you have equal-size faces, you'll achieve the same result. But generally, your formulation doesn't lead to the average value physically because it doesn't contribute the weighting! these are the formulations:
- your formulation: (1/N)*sum(shear)
- The correct formulation: (1/area)*sum(shear*area)
Bests,
Amir
Old   August 15, 2012, 12:25
Tian Coulsting
Ah, I see... I did not realise the calculated values were weighted by the size of the cells!
Looking over the script I have an understanding of all aspects except, why do you write this:
volTensorField T=mu*(gradU+gradU.T());
T you say is the stress tensor which is the Jacobian of the velocity (i.e. gradU) and I assume you multiply by mu because it's as good a stage as any to do so. However, why the "+gradU.T()"?
Cheers
Tian
Old   August 15, 2012, 15:43
Amir's Avatar
Amir
Tian
Because it's the constitutive equation! Take a look over basic fluid mechanic equation in a continuum media.
(T=2*mu*D) for incompressible flow
D : symmetric part of grad(U)
Bests,
Amir
Old   August 26, 2012, 06:02
Tian Coulsting
Hi again!
I seem to be getting far too high values out for wall shear stress. I have implemented a monitor in my solver, so that it outputs average wall shear stress over the top surface of my simulation. The code looks as follows:
volTensorField gradU=fvc::grad(U);
volVectorField nn
IOobject
"nn",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
mesh,
vector::zero
forAll(nn.boundaryField(), patchI)
nn.boundaryField()[patchI] =
-mesh.Sf().boundaryField()[patchI]
/mesh.magSf().boundaryField()[patchI]
forAll(wallShearStress.boundaryField(), patchI)
wallShearStress.boundaryField()[patchI] =
nn.boundaryField()[patchI] & T.boundaryField()[patchI];
forAll(normal.boundaryField(), patchI)
normal.boundaryField()[patchI] =
(nn.boundaryField()[patchI] & wallShearStress.boundaryField()[patchI])
*nn.boundaryField()[patchI];
forAll(shear.boundaryField(), patchI)
shear.boundaryField()[patchI] =
wallShearStress.boundaryField()[patchI]-normal.boundaryField()[patchI];
<< endl;
scalar area = gSum(mesh.magSf().boundaryField()[topSurfacePatch]);
scalar avgWSS = gSum(mag(shear.boundaryField()[topSurfacePatch]))/area;
// reduce(avgWSS,sumOp<scalar>());
Info << "Monitor: at Time = " << runTime.timeName() << " -- Average wall shear stress over top surface= " << avgWSS <<" [kg/(m*s^2)] " << "Area = " << area << " [m^2] ";
The values I am getting out are far too high for my simulation, for example average wall shear stress of 40 where mean velocity is magnitude 1. I have searched through the code trying to work out where the issue is occurring. Do you have any suggestions please?
Cheers,
Tian
Old   August 26, 2012, 06:21
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Tian,
I think (am certain) that the error is in the following line:
where, if you want a area weighted average, you should do
scalar avgWSS = gSum(mag(shear.boundaryField()[topSurfacePatch]) * mesh.magSf().boundaryField()[topSurfacePatch])/area;
Kind regards,
Niels
TianC likes this.
ngj is offline   Reply With Quote
Old   August 26, 2012, 06:40
Tian Coulsting
Ahhh... That is so much better.
Thank you Niels you're a life saver!
Tian
Old   August 26, 2012, 06:47
ngj
No problem.
BTW: In stead of making the stress tensor yourself, you could benefit from the turbulence model by calling devReff(). The only thing to remember is that this tensor is also non-tangential with the wall, so you have to perform the same projection (as you already do) onto the boundary face.
The upside of using the turbulence model is that you do not have to implement turbulence model specific shear stress methods, because the turbulence model itself tells, how the shear stress is defined.
/ Niels
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
2D wall shear stress yossarian88 STAR-CCM+ 0 February 21, 2011 14:12
relationship between wall shear stress and TKE winter FLUENT 0 December 11, 2007 18:11
Macro to set Wall Shear Stress Satish FLUENT 4 November 26, 2003 15:46
WALL SHEAR STRESS Min-Hua Wang CFX 0 April 3, 2002 18:40
