Reynolds Stress Custom BC
Old   September 9, 2011, 08:50
Question Reynolds Stress Custom BC
Bill
maninthemail is on a distinguished road
Greetings. What I'm trying to do is have an inlet BC calculated in the same way as "turbulentIntensityKineticEnergyInlet" (k calculated using a fractional fluctuation from the mean velocity). Instead of applying the calculated value to k, I'd like to divide it by 3 and apply it to each normal (diagonal) component of the Reynolds stress tensor. I can't find an existing BC which does this. If I'm just being unobservant, please could you point me in the right direction then read no further.
Right, so my custom BC is pretty much just a copy of "$FOAM_SRC/finiteVolume/fields/fvPatchFields/derived/turbulentIntensityKineticEnergyInlet/turbulentIntensityKineticEnergyInletFvPatchScalarF ield.C" with the word "scalar" replaced with "symmtensor" pretty much everywhere. There are two things I can't figure out how to do. The first is actually how to apply the calculated normal stresses to the tensor in the "updateCoeffs()" function.
void Foam::turbulentIntensityRInletFvPatchSymmTensorField::updateCoeffs()
        if (updated()) return;
        const fvPatchVectorField& Up = patch().lookupPatchField<volVectorField, vector>(UName_);
        const fvsPatchScalarField& phip = patch().lookupPatchField<surfaceScalarField, scalar>(phiName_);
         * //ORIGINAL SCALAR K CALCULATION
         * this->refValue() = 1.5*sqr(intensity_)*magSqr(Up);
         * this->valueFraction() = 1.0 - pos(phip);
         * inletOutletFvPatchScalarField::updateCoeffs();
         * //NEW TENSOR CALCULATION GOES HERE ?????????
         * want to apply "0.5*sqr(intensity_)*magSqr(Up)" to the diagonal components of R
        fixedValueFvPatchSymmTensorField::updateCoeffs();
Secondly, I can't seem too link even a non-functioning version. I can compile it, I can't link it. Previously, all I've had to do for custom BCs is to have the Make directory contain the files "files" and "options" which look something like
customBoundaryConditionFvPatchVectorField.C
LIB = $(FOAM_USER_LIBBIN)/libcustomBoundaryCondition
and
EXE_INC = -I$(LIB_SRC)/finiteVolume/lnInclude
LIB_LIBS = -lfiniteVolume
respectively. That's not working with the new thing, so presumably there's something else needs including for symmetric tensors. I have no idea what that is, so if someone could point me in the right direction, I'd be chuffed. Linking errors are below.
Many thanks
Will
/usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../lib64/crt1.o: In function `_start':
/usr/src/packages/BUILD/glibc-2.11.2/csu/../sysdeps/x86_64/elf/start.S:109: undefined reference to `main'
Make/linux64IccDPOpt/turbulentIntensityRInletFvPatchSymmTensorField.o: In function `Foam::turbulentIntensityRInletFvPatchSymmTensorField::updateCoeffs()':
turbulentIntensityRInletFvPatchSymmTensorField.C:(.text+0x2155): undefined reference to `Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::typeName'
turbulentIntensityRInletFvPatchSymmTensorField.C:(.text+0x221c): undefined reference to `Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::typeName'
turbulentIntensityRInletFvPatchSymmTensorField.C:(.text+0x260e): undefined reference to `Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>::typeName'
turbulentIntensityRInletFvPatchSymmTensorField.C:(.text+0x26d5): undefined reference to `Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>::typeName'
Make/linux64IccDPOpt/turbulentIntensityRInletFvPatchSymmTensorField.o: In function `__sti__$E':
turbulentIntensityRInletFvPatchSymmTensorField.C:(.text+0x3389): undefined reference to `Foam::fvPatchField<Foam::SymmTensor<double> >::constructpatchConstructorTables()'
turbulentIntensityRInletFvPatchSymmTensorField.C:(.text+0x3390): undefined reference to `Foam::fvPatchField<Foam::SymmTensor<double> >::patchConstructorTablePtr_'
turbulentIntensityRInletFvPatchSymmTensorField.C:(.text+0x34f0): undefined reference to `Foam::fvPatchField<Foam::SymmTensor<double> >::constructpatchMapperConstructorTables()'
turbulentIntensityRInletFvPatchSymmTensorField.C:(.text+0x34f7): undefined reference to `Foam::fvPatchField<Foam::SymmTensor<double> >::patchMapperConstructorTablePtr_'
turbulentIntensityRInletFvPatchSymmTensorField.C:(.text+0x3651): undefined reference to `Foam::fvPatchField<Foam::SymmTensor<double> >::constructdictionaryConstructorTables()'
turbulentIntensityRInletFvPatchSymmTensorField.C:(.text+0x3658): undefined reference to `Foam::fvPatchField<Foam::SymmTensor<double> >::dictionaryConstructorTablePtr_'
Make/linux64IccDPOpt/turbulentIntensityRInletFvPatchSymmTensorField.o: In function `Foam::fixedValueFvPatchField<Foam::SymmTensor<double> >::type() const':
turbulentIntensityRInletFvPatchSymmTensorField.C:(.gnu.linkonce.t._ZNK4Foam22fixedValueFvPatchFieldINS_10SymmTensorIdEEE4typeEv[.gnu.linkonce.t._ZNK4Foam22fixedValueFvPatchFieldINS_10SymmTensorIdEEE4typeEv]+0x3): undefined reference to `Foam::fixedValueFvPatchField<Foam::SymmTensor<double> >::typeName'
Make/linux64IccDPOpt/turbulentIntensityRInletFvPatchSymmTensorField.o: In function `Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const':
turbulentIntensityRInletFvPatchSymmTensorField.C:(.gnu.linkonce.t._ZNK4Foam14objectRegistry12lookupObjectINS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEEEERKT_RKNS_4wordE[.gnu.linkonce.t._ZNK4Foam14objectRegistry12lookupObjectINS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEEEERKT_RKNS_4wordE]+0x1c2): undefined reference to `Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::typeName'
turbulentIntensityRInletFvPatchSymmTensorField.C:(.gnu.linkonce.t._ZNK4Foam14objectRegistry12lookupObjectINS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEEEERKT_RKNS_4wordE[.gnu.linkonce.t._ZNK4Foam14objectRegistry12lookupObjectINS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEEEERKT_RKNS_4wordE]+0x288): undefined reference to `Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::typeName'
Make/linux64IccDPOpt/turbulentIntensityRInletFvPatchSymmTensorField.o: In function `Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const& Foam::objectRegistry::lookupObject<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >(Foam::word const&) const':
turbulentIntensityRInletFvPatchSymmTensorField.C:(.gnu.linkonce.t._ZNK4Foam14objectRegistry12lookupObjectINS_14GeometricFieldIdNS_13fvsPatchFieldENS_11surfaceMeshEEEEERKT_RKNS_4wordE[.gnu.linkonce.t._ZNK4Foam14objectRegistry12lookupObjectINS_14GeometricFieldIdNS_13fvsPatchFieldENS_11surfaceMeshEEEEERKT_RKNS_4wordE]+0x1c2): undefined reference to `Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>::typeName'
turbulentIntensityRInletFvPatchSymmTensorField.C:(.gnu.linkonce.t._ZNK4Foam14objectRegistry12lookupObjectINS_14GeometricFieldIdNS_13fvsPatchFieldENS_11surfaceMeshEEEEERKT_RKNS_4wordE[.gnu.linkonce.t._ZNK4Foam14objectRegistry12lookupObjectINS_14GeometricFieldIdNS_13fvsPatchFieldENS_11surfaceMeshEEEEERKT_RKNS_4wordE]+0x288): undefined reference to `Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>::typeName'
Make/linux64IccDPOpt/turbulentIntensityRInletFvPatchSymmTensorField.o: In function `Foam::fvPatchField<Foam::SymmTensor<double> >::type() const':
turbulentIntensityRInletFvPatchSymmTensorField.C:(.gnu.linkonce.t._ZNK4Foam12fvPatchFieldINS_10SymmTensorIdEEE4typeEv[.gnu.linkonce.t._ZNK4Foam12fvPatchFieldINS_10SymmTensorIdEEE4typeEv]+0x3): undefined reference to `Foam::fvPatchField<Foam::SymmTensor<double> >::typeName'
Make/linux64IccDPOpt/turbulentIntensityRInletFvPatchSymmTensorField.o: In function `Foam::fvPatchField<Foam::SymmTensor<double> >::addpatchConstructorToTable<Foam::turbulentIntensityRInletFvPatchSymmTensorField>::~addpatchConstructorToTable()':
turbulentIntensityRInletFvPatchSymmTensorField.C:(.gnu.linkonce.t._ZN4Foam12fvPatchFieldINS_10SymmTensorIdEEE26addpatchConstructorToTableINS_46turbulentIntensityRInletFvPatchSymmTensorFieldEED1Ev[.gnu.linkonce.t._ZN4Foam12fvPatchFieldINS_10SymmTensorIdEEE26addpatchConstructorToTableINS_46turbulentIntensityRInletFvPatchSymmTensorFieldEED1Ev]+0x2): undefined reference to `Foam::fvPatchField<Foam::SymmTensor<double> >::destroypatchConstructorTables()'
Make/linux64IccDPOpt/turbulentIntensityRInletFvPatchSymmTensorField.o: In function `Foam::fixedValueFvPatchField<Foam::SymmTensor<double> >::gradientInternalCoeffs() const':
turbulentIntensityRInletFvPatchSymmTensorField.C:(.gnu.linkonce.t._ZNK4Foam22fixedValueFvPatchFieldINS_10SymmTensorIdEEE22gradientInternalCoeffsEv[.gnu.linkonce.t._ZNK4Foam22fixedValueFvPatchFieldINS_10SymmTensorIdEEE22gradientInternalCoeffsEv]+0x6d): undefined reference to `Foam::fvPatch::deltaCoeffs() const'
Make/linux64IccDPOpt/turbulentIntensityRInletFvPatchSymmTensorField.o: In function `Foam::fixedValueFvPatchField<Foam::SymmTensor<double> >::gradientBoundaryCoeffs() const':
turbulentIntensityRInletFvPatchSymmTensorField.C:(.gnu.linkonce.t._ZNK4Foam22fixedValueFvPatchFieldINS_10SymmTensorIdEEE22gradientBoundaryCoeffsEv[.gnu.linkonce.t._ZNK4Foam22fixedValueFvPatchFieldINS_10SymmTensorIdEEE22gradientBoundaryCoeffsEv]+0x18): undefined reference to `Foam::fvPatch::deltaCoeffs() const'
Make/linux64IccDPOpt/turbulentIntensityRInletFvPatchSymmTensorField.o: In function `Foam::fvPatchField<Foam::SymmTensor<double> >::addpatchMapperConstructorToTable<Foam::turbulentIntensityRInletFvPatchSymmTensorField>::~addpatchMapperConstructorToTable()':
turbulentIntensityRInletFvPatchSymmTensorField.C:(.gnu.linkonce.t._ZN4Foam12fvPatchFieldINS_10SymmTensorIdEEE32addpatchMapperConstructorToTableINS_46turbulentIntensityRInletFvPatchSymmTensorFieldEED1Ev[.gnu.linkonce.t._ZN4Foam12fvPatchFieldINS_10SymmTensorIdEEE32addpatchMapperConstructorToTableINS_46turbulentIntensityRInletFvPatchSymmTensorFieldEED1Ev]+0x2): undefined reference to `Foam::fvPatchField<Foam::SymmTensor<double> >::destroypatchMapperConstructorTables()'
Make/linux64IccDPOpt/turbulentIntensityRInletFvPatchSymmTensorField.o: In function `Foam::fvPatchField<Foam::SymmTensor<double> >::adddictionaryConstructorToTable<Foam::turbulentIntensityRInletFvPatchSymmTensorField>::~adddictionaryConstructorToTable()':
turbulentIntensityRInletFvPatchSymmTensorField.C:(.gnu.linkonce.t._ZN4Foam12fvPatchFieldINS_10SymmTensorIdEEE31adddictionaryConstructorToTableINS_46turbulentIntensityRInletFvPatchSymmTensorFieldEED1Ev[.gnu.linkonce.t._ZN4Foam12fvPatchFieldINS_10SymmTensorIdEEE31adddictionaryConstructorToTableINS_46turbulentIntensityRInletFvPatchSymmTensorFieldEED1Ev]+0x2): undefined reference to `Foam::fvPatchField<Foam::SymmTensor<double> >::destroydictionaryConstructorTables()'
Make/linux64IccDPOpt/turbulentIntensityRInletFvPatchSymmTensorField.o: In function `Foam::fvPatchField<Foam::SymmTensor<double> >::snGrad() const':
turbulentIntensityRInletFvPatchSymmTensorField.C:(.gnu.linkonce.t._ZNK4Foam12fvPatchFieldINS_10SymmTensorIdEEE6snGradEv[.gnu.linkonce.t._ZNK4Foam12fvPatchFieldINS_10SymmTensorIdEEE6snGradEv]+0x47b): undefined reference to `Foam::fvPatch::deltaCoeffs() const'
make: *** [OpenFOAM.out] Error 1
maninthemail is offline   Reply With Quote
Old   September 15, 2011, 06:37
Default Bump
Bill
Bump. Still stuck on this problem. Anyone?
Old   November 14, 2011, 08:41
Albrecht vBoetticher
vonboett is on a distinguished road
I had a similar problem when introducing a new visosity model. I used to call 'wmake' from the folder where the 'Make' directory was placed, in this case transportModels/incompressible, after including my model to the 'files' file in the Make folder. The problem was solved by calling 'wmake libso incompressibl' from one folder above (transportModels) where the Allwmake file was stored.
vonboett is offline   Reply With Quote
Old   November 14, 2011, 14:58
Default Solved
Bill
Yes, sorry, I figured all this out a while ago now. "wmake libso" is precisely what I should have been typing. Also, setting of the tensor variable was achieved using the code below.
        // boundary velocity and phi
        // one third of the turbulent intensity
        scalarField value = 0.5*sqr(intensity_)*magSqr(Up);
        // identity matix as a symmTensor
        symmTensor I(1,0,0,1,0,1);
        // the stress is then a symmetric tensor field with non-zero diagonal elements equal to "value"
        this->refValue() = value * I;
boundary, condition, custom, rstm, tensor
New implemented algebraic Reynolds stress model volker OpenFOAM 13 October 21, 2013 01:01
Reynolds Stress Models Jade M Main CFD Forum 0 April 21, 2010 17:38
Reynolds Stress Boundary Conditions tstorm FLUENT 0 July 27, 2009 15:44
Questions about the Reynolds stress model empirer2002 Main CFD Forum 1 January 5, 2006 08:37
reynolds stress tufito Main CFD Forum 3 March 10, 2005 16:40
