September 6, 2011, 07:44 |
Outlet patch with a hole inside
Rep Power: 15 |
Hi there
I am using openfoam to model the interface between 2 fluids. I have a .stl model, and used snappyhexmesh to create my mesh. I defined a bounding box around this model, so that one of the faces would be the inlet and others would be the outlet. I succeeded, but the time steps were too small. (That is a problem I would also like to ask) The problem: Now, I want to create the inlet so that it would be on one of the faces of the cube, however smaller than the face. The small patch on the face of the cube would be the inlet, and the rest of the face would be the outlet. The outlet therefore has a hole inside, and I could not find a way to model it. Is there any way to construct a polygon, and subtract a smaller polygon from that? The other problem is that the time steps are too small. I am guessing the reasons may be:
Thanks in advance http://www.2shared.com/file/C_we4D7D/trial1tar.html |
September 7, 2011, 07:53 |
Rep Power: 15 |
I have dealt with the small time step issue by decreasing the number of cells. Now, I only want to know if there is a way to create a perforated patch.
I would appreciate the smallest clue, I am on a tight schedule now. |
September 7, 2011, 08:08 |
Niklas Nordin
Rep Power: 29 |
If I have understood you correctly, you want openfoam to guess where the hole is?
You need to have a properly defined stl, where the hole-patch is defined as a separate part. |
September 7, 2011, 11:10 |
Rep Power: 15 |
I have the coordinates for the hole, I just don't know how to implement the hole, in this case a square hole on a square plate. I think I managed to do it by dividing the blocks into four pieces, but that was easy because of the geometry. For example, what could we do if we were to define a ring (circular hole on a circular plate) as a patch?
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 18:16 |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 03:10 |
Patch a bubble inside turbulent flow | Helmi | FLUENT | 0 | February 4, 2011 05:54 |
[Netgen] Create boundary | fabrizio | OpenFOAM Meshing & Mesh Conversion | 1 | October 26, 2008 15:12 |
How to specify a patch on a small hole | allegro | CFX | 0 | January 28, 2003 06:26 |
