August 26, 2011, 12:42 |
p relaxationFactor in twoPhaseEulerFoam
Hamed Kh.
Rep Power: 16 |
dear foamers
i`m using twoPhaseEulerFoam for my simuation. relaxationfactor for my simulation is: relaxationFactors { Ua 0.7; Ub 0.7; p 0.3; alpha 0.2; beta 0.2; Theta 0.2; k 0.4; epsilon 0.4; } but an error was occure only for p (pressure relaxation factor) !! the error is: Courant Number mean: 0.00035655 max: 0.0004 Max Ur Courant Number = 0.0004 deltaT = 1.1999e-05 Time = 1.1999e-05 PIMPLE: iteration 1 DILUPBiCG: Solving for alpha, Initial residual = 1.08695e-06, Final residual = 1.52185e-22, No Iterations 1 Dispersed phase volume fraction = 0.11 Min(alpha) = 0 Max(alpha) = 0.55 DILUPBiCG: Solving for alpha, Initial residual = 8.6948e-07, Final residual = 1.52191e-22, No Iterations 1 Dispersed phase volume fraction = 0.11 Min(alpha) = 0 Max(alpha) = 0.55 kinTheory: max(Theta) = 1e-05 kinTheory: min(nua) = 2.94999e-08, max(nua) = 2.97152e-06 kinTheory: min(pa) = 0, max(pa) = 1.20197e-10 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0810062, No Iterations 4 --> FOAM FATAL ERROR: previous iteration field IOobject: volScalarField p "/home/hamed/OpenFOAM/hamed-2.0.0/mycase/al96-H0=10-03/0" not stored. Use field.storePrevIter() at start of iteration. From function GeometricField<Type, PatchField, GeoMesh>:revIter() const in file /home/hamed/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/GeometricField.C at line 844. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) in "/home/hamed/OpenFOAM/OpenFOAM-2.0.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/home/hamed/OpenFOAM/OpenFOAM-2.0.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 in "/home/hamed/OpenFOAM/OpenFOAM-2.0.0/platforms/linuxGccDPOpt/bin/twoPhaseEulerFoam" #3 in "/home/hamed/OpenFOAM/OpenFOAM-2.0.0/platforms/linuxGccDPOpt/bin/twoPhaseEulerFoam" #4 in "/home/hamed/OpenFOAM/OpenFOAM-2.0.0/platforms/linuxGccDPOpt/bin/twoPhaseEulerFoam" #5 in "/home/hamed/OpenFOAM/OpenFOAM-2.0.0/platforms/linuxGccDPOpt/bin/twoPhaseEulerFoam" #6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #7 in "/home/hamed/OpenFOAM/OpenFOAM-2.0.0/platforms/linuxGccDPOpt/bin/twoPhaseEulerFoam" Aborted any solution or idea??? |
August 26, 2011, 13:51 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings hkhosravi,
OpenFOAM's take on folder and file names is that the file system reflects the program variables... with the exception of time folders which should be properly formatted numbers. Therefore "al96-H0=10-03" is a very bad folder name! I'm stuned how OpenFOAM didn't stop right at the beginning telling you that the name "al96-H0=10-03" is invalid... Try again with another folder name for your case! Something more... simple! You could try with "al96_H0__10_03". Best regards, Bruno
August 26, 2011, 15:16 |
Hamed Kh.
Rep Power: 16 |
Hi Bruno
thanks for quick reply. I changed the folder name to "al96_03" also "al96", but there are the same error. i`m sure the problem relate to "p" relaxation factor, because when i delete it, everything is correct !! |
August 26, 2011, 15:39 |
#4 | ||
Bruno Santos
Rep Power: 128 |
In case you can't define it yourself, I think you can use the following instructions to write the p field: http://openfoamwiki.net/index.php/Ti...gisteredObject
August 26, 2011, 16:53 |
Hamed Kh.
Rep Power: 16 |
How could I have not spotted this before... Does the file "0/p" exist and have the necessary boundaries and field? That's what the error message is talking about![/QUOTE]
The file "0/p" exist and have the correct BC, because I can run the case without using relaxation factor for "p". also, In the stored time directory, "p" field exist and I can see pressure field in paraview. |
August 26, 2011, 17:11 |
Bruno Santos
Rep Power: 128 |
After googling it a bit... It's a bug! See http://www.openfoam.com/mantisbt/view.php?id=245
It should be fixed in OpenFOAM 2.0.1, so you should upgrade! Best regards, Bruno
August 27, 2011, 03:18 |
Hamed Kh.
Rep Power: 16 |
yes, it`s a bug and solved in OF 2.0.1.
thanks Bruno Regards |
Something wrong in UEqns.H within twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM | 2 | June 24, 2011 11:48 |
twoPhaseEulerFoam | freemankofi | OpenFOAM | 0 | May 23, 2011 17:24 |
stratified horizontal two phase flow usinfg twoPhaseEulerFoam | karthik1414 | OpenFOAM | 0 | April 12, 2011 10:57 |
problems in Two Phase flow using twoPhaseEulerFoam with OpenFoam 1.6 | raagh77 | OpenFOAM Running, Solving & CFD | 0 | March 6, 2010 06:11 |
TwoPhaseEulerFoam bed tutorial case stable in 1.5, crashes in 1.6 | hemph | OpenFOAM | 3 | December 5, 2009 05:19 |
