converting ICEM grid to OpenFOAM fails
Old   August 24, 2011, 05:33
Default converting ICEM grid to OpenFOAM fails
MikeyMike is on a distinguished road
Dear folks,
I have the following problem using ICEM as a mesher. I am meshed up a bearing chamber with several different faces and two different bodies which are representing different volumes with different media (air, oil). The problem is this error-message coming out when trying to convert (fluentMeshToFoam XXX.msh) the net into OpenFOAM. I donīt know what to do or what is wrong - where lies the problem to solve?? This is the error-message:
Create time
Dimension of grid: 3
Number of points: 86400
Reading points
Number of cells: 80736
Other readCellGroupData: c 1 13b60 1 4
Reading uniform cells
number of faces: 244992
Reading uniform faces
Read zone1:12 name:BODY patchTypeID:fluid
Reading zone data
Read zone1:13 name:int_BODY patchTypeID:interior
Reading zone data
Read zone1:14 name:WALLFRONT patchTypeID:wall
Reading zone data
Read zone1:15 name:WALLOUTER patchTypeID:wall
Reading zone data
Read zone1:16 name:WALLINNER patchTypeID:wall
Reading zone data
FINISHED LEXING
dimension of grid: 3
Creating shapes for 3-D cells
--> FOAM FATAL ERROR:
Cannot find match for face 5.
Model: hex model face: 4(1 2 6 5) Mesh faces:
6
4(6 7 3 2)
4(3 7 5 1)
4(4 6 2 0)
4(5 7 6 4)
4(2 3 1 0)
4(6 7 3 2)
Matched points: 8(6 4 0 2 7 5 1 3)
From function create3DCellShape(const label cellIndex, const labelList& faceLabels, const labelListList& faces, const labelList& owner, const labelList& neighbour, const label fluentCellModelID)
in file create3DCellShape.C at line 281.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/itsnas/michael/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/itsnas/michael/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::create3DCellShape(int, Foam::List<int> const&, Foam::List<Foam::face> const&, Foam::List<int> const&, Foam::List<int> const&, int) in "/home/itsnas/michael/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/fluentMeshToFoam"
#3 main in "/home/itsnas/michael/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/fluentMeshToFoam"
#4 __libc_start_main in "/lib64/libc.so.6"
#5 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Abort
Exit 134
Can anybody help me where to begin with this error?? Thanks a lot in advance!! Cheers, Mike
MikeyMike is offline   Reply With Quote
Old   August 24, 2011, 08:39
lindner is on a distinguished road
Try using fluent3DMeshToFoam , and the mesh must be saved/exported in the ascii mode, not binary.
lindner is offline   Reply With Quote
Old   August 25, 2011, 07:22
Ok now converting/transferring into OF went fine..!
But here another error which came out while trying to run interFoam:
| \\ / O peration | Version: 1.6.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6.x-8ff188cd556c
Exec : interFoam
Date : Aug 25 2011
Time : 12:06:09
Host : itsnc1
PID : 32184
Case : /home/itsnas/michael/OpenFOAM/michael-1.6.x/run/Tests/Running/test/TestNewest2
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Reading g
Reading field p
Reading field alpha1
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
time step continuity errors : sum local = 4.96605e-17, global = 4.4311e-18, cumulative = 4.4311e-18
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 1e-300
Specified mass inflow : 3.84968e-17
Specified mass outflow : 4.60399e-17
Adjustable mass outflow : 0
From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p
in file cfdTools/general/adjustPhi/adjustPhi.C at line 116.
FOAM exiting
Exit 1
Hope anybody can make something out of this..!! Where can I solve the problem - The thing is: I donīt have an in-/outlet yet, they are meant to be additions later..
Cheers, Mike
converting error, icem cfd, openfoam
[Commercial meshers] Pointwise grid export to Openfoam Eren10 OpenFOAM Meshing & Mesh Conversion 15 May 30, 2019 18:10
[ICEM] Exporting Grid Volumes/Areas from ICEM to Calculate Discretization Error Josh ANSYS Meshing & Geometry 4 May 20, 2010 14:40
How to generate 2D grid of CFL3D in ICEM? aladdincham Main CFD Forum 0 March 11, 2010 03:19
[Gmsh] Error converting Gmsh mesh to OpenFOAM format Martin_ OpenFOAM Meshing & Mesh Conversion 3 December 9, 2009 10:35
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
