Stefan
Rep Power: 17 ![]() |
I want to install OpenFoam 2.0.1 on a server with suse enterprise. The installation of OpenFoam was ok no errors. Now I want to install paraview 3.10.1. The first problem was the missing cmake but I installed cmake 2.8.5. Now my problem is this output: Code:
CMake Error: The following variables are used in this project, but they are set to NOTFOUND. Please set them or make sure they are set and tested correctly in the CMake files: QT_QTWEBKIT_INCLUDE_DIR (ADVANCED) used as include directory in directory /home/preibisch/OpenFOAM/ThirdParty-2.0.1/ParaView-3.10.1/VTK/GUISupport/Qt -- Configuring incomplete, errors occurred! Starting make make: *** Keine Targets angegeben und keine »make«-Steuerdatei gefunden. Schluss. real 0m0.005s user 0m0.004s sys 0m0.000s Done make Installing ParaView to /home/preibisch/OpenFOAM/ThirdParty-2.0.1/platforms/linux64Gcc/paraview-3.10.1 make: *** Keine Regel, um »install« zu erstellen. Schluss. --- Installation complete for paraview-3.10.1 Set environment variables: export ParaView_DIR=/home/preibisch/OpenFOAM/ThirdParty-2.0.1/platforms/linux64Gcc/paraview-3.10.1 export PATH=$ParaView_DIR/bin:$PATH export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-3.10 --- Done Code:
QMake version 2.01a Using Qt version 4.6.2 in /usr/lib64 Code:
Checking basic system... ----------------------------------------------------------------------- Shell: /bin/bash Host: ansyscfd OS: Linux version 2.6.32.36-0.5-default User: preibisch System check: PASS ================== Continue OpenFOAM installation. ![]() What is the problem? Can somebody help me? thanks Preibie |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Greetings Preibie,
I've got two solutions for you:
Bruno
Joel Lehikoinen
Rep Power: 15 ![]() |
I got the same error when trying to install Paraview on SuSe Linux Enterprise Server 11 SP1. After installing the libQtWebKit-devel Paraview compiled ok, but when I try to start paraview, I just get an error about a missing GLX extension:
ERROR: In /home/lehikjoe/OpenFOAM/ThirdParty-2.0.1/ParaView-3.10.1/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 404 vtkXOpenGLRenderWindow (0x164f920): Could not find a decent visual ... ERROR: In /home/lehikjoe/OpenFOAM/ThirdParty-2.0.1/ParaView-3.10.1/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 611 vtkXOpenGLRenderWindow (0x164f920): GLX not found. Aborting. |
Bruno Santos
Stefan
thanks for the help. Your idea was good. I installed the libQtWebKit-devel package and installed without problems paraview and the reader
#6 | |
Joel Lehikoinen
Bruno Santos
Hi Joel,
Mmm... I vaguely remember that the packages freeglut, glxgears (Debian only, if I'm not mistaken) and the drivers for the graphics card should have the missing GLX stuff. The "Mesa" drivers should also have it, but Mesa is for CPU based graphics, not GPU. But neither one of these worked before starting ParaView?
Bruno
[OpenFOAM] Segmentation fault with paraview 3.10.1 | aot | ParaView | 5 | June 5, 2023 01:32 |
[General] Paraview nice animation | PyGloo | ParaView | 4 | June 7, 2012 12:34 |
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? | lentschi | OpenFOAM Installation | 1 | March 9, 2011 02:32 |
Paraview not found | fusij | OpenFOAM Installation | 2 | January 1, 2011 20:44 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
