extrudeMesh - stop edge and cell removal
Old   August 23, 2011, 07:31
Default extrudeMesh - stop edge and cell removal
Daniel
drrbradford is on a distinguished road
I'm having problems with sweeping a 2D mesh.
I need to change to the threshold for the lengths below which the edges and cells are removed automatically by the collageEdges part of the extrudeMesh utility.
I have altered the mergeDim value in extrudeMesh.C to a very small number (1E-20 * d) but this didn't make any difference and I'm not really comfortable with changing any more code that I don't understand.
Can anybody direct me as to where I can alter this threshold value?
Cheers.
I've attached screenshots of the problems it causes. The first is the 2D mesh I would like to sweep. The second is a clip plane showing the problems that deletion of small volumes causes with the geometry.
drrbradford is offline   Reply With Quote
Old   August 23, 2011, 07:39
Daniel
A little more info:
When I run extrudeMesh I get the following type of message:
Merging edge (8530 8531) since length 0 << 0.042625
In this case, the 0 refers to the removal of the edges created at the axis of rotation (I assume). It is the value of "0.042625" I would like to alter.
Old   August 23, 2011, 09:53
Daniel
Converting the mesh to metres from mm was a good start. However, I'm still having problems with the small volumes in the boundary layer, close to the axis of rotation.
Old   August 24, 2011, 12:19
Daniel
I've solved the problem and have learned a tiny bit about programming while I've been at it.
For anyone who needs to deal with this in future:
1. Change mergeDim value in the file /OpenFOAM-X.Y.Z/applications/utilities/mesh/generation/extrude/extrudeMesh/extrudeMesh.C to some appropriate value. Don't make it too small if you still want to remove the singularities created at the axis of symmetry.
2. Delete the file applications/utilities/mesh/generation/extrude/extrudeMesh/Make/<PLATFOM>/extrudeMesh.o
3. Open a terminal in the applications/utilities/mesh/generation/extrude/extrudeMesh/ directory and run wmake.
Boom, threshold changed.
cell volume, extrudemesh, revolved mesh
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 21:05
gradient calculation of cell centered finite volume method zhengjg Main CFD Forum 10 November 12, 2012 00:13
[Commercial meshers] Star mesh import problem chris1980 OpenFOAM Meshing & Mesh Conversion 20 May 8, 2006 02:07
