laplacianFoam blow up
Old   August 16, 2011, 04:43
Default laplacianFoam blow up
Raph Raggatt
Rapha is on a distinguished road
Hello all,
I am struggling with a laplacianFoam case, with just a simple heat transfer case. I have built a mesh in Salome and exported it fine into openfoam,
Settings are:
Transport Properties: DT = 19e-5
System settings are as tutorial
T values:
inlet = 773K
outlet1 = zeroGradient
outlet2 = zeroGradient
defaultFaces = zeroGradient
Walls = $internalField (273K)
I run the case for 100000 steps and for the first 50,000 or so the simulation runs as expected. However, after that it starts going crazy and temperature goes exceedingly high towards the end. I've attached some screenshots and also of Surface with edges to show what the mesh looks like. dz is 0.01.
Any ideas why it begins to blow up? Surely the temperature should leave the outlets?
Thanks,
Rapha
Rapha is offline   Reply With Quote
laplacian
Mixed BC - heat transfer - laplacianFoam bhh OpenFOAM Pre-Processing 65 February 7, 2019 10:57
Absurd results for blow down sim HELP plz! MatCFD OpenFOAM 0 May 31, 2011 10:30
create own case for laplacianFoam rahulrp OpenFOAM Pre-Processing 6 April 8, 2010 01:03
laplacianfoam with solidification dakos OpenFOAM 1 November 14, 2009 07:15
laplacianFoam and GAMG karamiag OpenFOAM Running, Solving & CFD 0 May 21, 2009 12:09
