FEM implementation in OpenFOAM 2.0.0 or later?
Old   August 11, 2011, 10:49
Default FEM implementation in OpenFOAM 2.0.0 or later?
seboxx is on a distinguished road
Hi there,
I was wondering if there is a way to use a finite element algorithm within the OpenFOAM 2.0.x. I did quite a bit of research on the web, and only found some libraries for older versions e.g. 1.5
Is there any library supporting FEM for the present version? Does anyone have experience with OpenFOAM and FEM? Any useful links?
I mean there is a lot of stuff like 'it is also possible to apply finite element discretization'. But i wasnt able to find any examples, tutorials, pieces of code or any advice...
I have used OpenFOAM a bit now, and feel quite comfortable with the way it works. For my thesis i am asked to use a FEM algorithm though, it would be a shame if I couldnt do it within the Foam framework.
Thank you for your help,
sebastian
seboxx is offline   Reply With Quote
Old   August 12, 2011, 03:09
Kathrin Kissling
kathrin_kissling is on a distinguished road
Hi seboxx,
I don't know whether it's there in 2.0 but there is quite some FEM in the OpenFOAM-1.6ext version. It is especially used for mesh motion but there are also some basic FEM solvers.
Best
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   August 12, 2011, 03:29
Elvis
elvis will become famous soon enough
http://www.openfoamworkshop.org/6th_...iff_slides.pdf
Contact stress analysis in OpenFOAM: application to hip joint bones
Philip Cardiff (University College Dublin, Ireland)
I think if you go through the presentations of the OF-workshop of the past years you will find some FEM-stuff => mostly Fluid Structure Interaction (FSI) but in the past these were (mostly) done in OF alone.
elvis is offline   Reply With Quote
Old   August 15, 2011, 08:24
Thank you for your help!
OpenFoam 2.0.0 installation Jan_Peters OpenFOAM Installation 86 April 27, 2012 06:32
OpenFOAM 2.0.0 and Turbomachinery lindner OpenFOAM 0 July 8, 2011 08:35
MPI implementation of OpenFOAM Jamshidi OpenFOAM 7 June 25, 2011 10:19
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
