August 3, 2011, 11:25 |
snapEdge not working
Dave Crossley
Rep Power: 16 |
Hey OFer's,
I have been having trouble using the snapEdge utility. Earlier in the year I have had no trouble using it with great results but since I have returned for some reason the command is not found. I'm using the same technique and very little has changed with my geometry. I'm wondering if either snapEdge is now not available OR I'm I've missed a step somewhere. Command terminal steps... 1) ideasUnvToFoam [file.unv] 2) snappyHexMesh 3) snapEdge I have all the right stl's and folder written correctly, snapEdge doesn't give any error other than it can not be found. Am I missing something? Cheers Dave |
August 3, 2011, 16:43 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Dave,
Do you mean this snapEdge: http://openfoamwiki.net/index.php/Contrib_snapEdge If so, and by your description, it seems that you came back to another installation of OpenFOAM, in which you did not build snapEdge... therefore it's not available When built and available, the snapEdge executable is likely placed in the folder defined in FOAM_USER_APPBIN; to confirm this, run: Code:
ls -l $FOAM_USER_APPBIN Bruno
August 3, 2011, 21:15 |
Aidan
Rep Power: 16 |
As an alternative to snapEdge, you could use the new feature edge handling capabilities in snappyHexMesh
http://www.openfoam.com/news/snappyH...ature-edge.php |
August 4, 2011, 03:46 |
Niklas Nordin
Rep Power: 29 |
snapEdge is obsolete with the introduction of version 2.0.x
August 4, 2011, 05:26 |
Dave Crossley
Rep Power: 16 |
wyldckat,
What an idiot, how could I not find that snapEdge site, working perfectly now. School boy error. Thanks everyone. Have a great day Dave |
snapedge |
OpenFoam 1.7.1 in Ubuntu 10.04 won't start working | Leech | OpenFOAM Installation | 8 | August 10, 2014 21:42 |
DPM parallel is not working but serial is working | johnwinter | FLUENT | 1 | March 27, 2012 03:01 |
Working Principle of Micro-Oven | aero | Siemens | 2 | January 31, 2007 06:00 |
Help required on working of Micro-oven | aero | CFX | 4 | January 19, 2007 09:21 |
Help required on working of Woven | aero | FLUENT | 0 | January 16, 2007 07:25 |
