How to use cellZoneInjection, "numberDensity", anyone can help ?? |
Fábio César Canesin
Rep Power: 16 ![]() |
Hi all, I have tried to use cellZoneInjection to put particles in my case but I'm not understanding the behavior of the "numberDensity".
I was in the believe that the numberDensity was the number of particles per cell. Or the number of particles for the cellZone. But reading the source file .C, it looks like it is "the number of particles per cubic meter". http://foam.sourceforge.net/docs/cpp/a05068_source.html Is it right ?? So, my question relies. If I provide: flowrate (kg/s), diameter (distribution) and the density is know.. why the hell do I need some particle density O.o ?? injectionModel cellZoneInjection; //Inject particles at the cloudZone cellZoneInjectionCoeffs { numberDensity 5.87E+06;//Number density of particles in one cell massFlowRate 0.0024585;//Mass per second massTotal 0.0024585; parcelBasisType mass;//Reference propertie cellZone myCloud;//Cell zone to realize injection SOI 1e-6; //Start of injection U0 (89.4 0 0); //Initial particle velocity sizeDistribution //Used to infere the diameter { type uniform; uniformDistribution { minValue 1.9e-5; maxValue 2.1e-5; } } } Is that right ?? Can someone please confirm the behavior. |
vidyadhar
Rep Power: 10 ![]() |
Hello Fábio César Canesin,
I have seen this post recently. I, also, want to use cellZoneInjection in openfoam4.0 or caelus. If you have used it successfully, I request you to help me how to execute the same. Like, I need help in setting the injection models and parameters involved in it. I am using toposetDict to create the cellZone. Thanks in advance. Regards, vidyadhar |
Alejandro López
Rep Power: 13 ![]() |
In this type of injection, numberDensity is equal to the number of desired particles in the celZone divided by the cellZone volume. The setup is as follows (just an example for a random case): model1 { type cellZoneInjection; numberDensity 2.22e11;//Number of desired particles divided by the cellZone Volume SOI 0; //Star of Injection cellZone cellZoneInject;//cellZone defined for injection massTotal 3.686e-5; parcelBasisType fixed; nParticle 1; U0 (0 0 0.1); sizeDistribution { type normal; normalDistribution { expectation 40e-6; variance 10e-6; minValue 30e-6; maxValue 50e-6; } } }
Alex |
