Can anybody please check my boundary conditions?
Old   August 3, 2011, 05:47
Sukanta Rakshit
srakshit is on a distinguished road
Why the outlet pressure is set fixedValue = zero? It should be zeroGradient.
srakshit is offline   Reply With Quote
Old   August 3, 2011, 07:53
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Thank you Sukanta.
I changed the pressure boundary condition as the following:
boundaryField
    inlet
        type            fixedValue;
        value           uniform 0;
    outlet
	type            zeroGradient;
Now the overall flow field is more reasonable but the velocity is too high at some points and I still have some strange feature (see pic attached).
What do you think?
Thank you!
lovecraft22 is offline   Reply With Quote
Old   August 3, 2011, 08:00
BR
Balakrshnan Ramakrishnan is on a distinguished road
If the velocity is specified at the inlet, usually we take the case that outlet is at atmospheric pressure.
Since we use relative scale for pressure, we assume the atmospheric pressure is zero.
The outlet is to be set to zero if it is at atmospheric pressure.
If you get a pressure below zero, its less than atmospheric pressure.
I hope I am correct.
Balakrshnan Ramakrishnan is offline   Reply With Quote
Old   August 3, 2011, 08:04
Sukanta Rakshit
But why inlet is fixed at zero now? Change in to zeroGradient
You have 30 m/s constant flow. Just tell me one thing if U at inlet is 30 m/s and Pressure is zero in that patch...is it consistent?
Old   August 3, 2011, 08:09
BR
I am not able to make the mesh given in this case since I use OF-1.7.x.
But from blockMeshDict I can say there is something wrong with naming the patches.
I guess in this case the patches inlet and outlet are swapped. But I am not sure.
If the inlet is set to some velocity, say 30 m/s, the pressure is set to zeroGradient.
Also if the outlet is set to be with a pressure ( fixedValue )of zero , then the inlet
should be zeroGradient. I do this in my cases and I get good results
Old   August 3, 2011, 08:10
Sukanta Rakshit
I do not think the pressure specified in the solver is relative. So u should either keep it floating or keep the absolute pressure.
Old   August 3, 2011, 08:21
BR
The solver uses Gauge pressure - reference to the atmospheric pressure- where atmospheric pressure is zero. In absolute pressures negative value is not possible(except in some cases like trees). But in our simulation we get negative pressures all the time. So it cannot be absolute pressure. whatever we do in normal CFD(everyday) is Gauge pressure.
Hope this helps
Old   August 3, 2011, 08:48
lore
1. I had to change the inlet condition also because otherwise I got an error which basically said that the solver couldn't find any reference cell for pressure.
2. Pressure is relative, so (I think) you can have 30m/s velocity with 0 pressure because that mean that the pressure s the same as ambient static pressure
3. Inlet and outlet are fine, just checked them in paraview.
4. I ran the simulation for another 1000 iterations and the strange behavior underlined in previous pic disappeared but I'm still getting way too high velocity…
Old   August 3, 2011, 08:52
BR
@lovecraft22
Why is there a zero velocity line (vertical streak of blue)at the inlet? is it due to your boundary conditions?
Old   August 3, 2011, 08:56
Sukanta Rakshit
its because the velocity = 30 m/s at inlet.
what is the outlet velocity boundary in this case?
BR
May be you can have a look at my simulation -> see attached pic
Old   August 3, 2011, 08:59
lore
That's my inlet condition: he velocity is not 0 but 30m/s.
About the outlet, the velocity is around 3000 m/s!!
It's an hypersonic cylinder!
Old   August 3, 2011, 09:02
Sukanta Rakshit
what boundary condition you are using for outlet?
Also what pRefValue you are using?
Old   August 3, 2011, 09:08
lore
Could you upload your boundary conditions?
Thank you!
Old   August 3, 2011, 09:16
Sukanta Rakshit
Try these boundary settings
for pressure
inlet
type freestreamPressure;
outlet
for velocity
inlet
type freestream;
freestreamValue uniform (30 0 0);
outlet
type freestream;
Old   August 3, 2011, 09:28
lore
You have to define one pressure value at least.
I set the pressure value to 0 at the inlet and the rest as you suggested.
Now it's running, let's see what comes out.
Old   August 3, 2011, 09:41
BR
Oops i thought you are just doing low velocity simulations.
which solver you use for hypersonic flows?
Old   August 3, 2011, 09:43
lore
I was just kidding about the fact that though I'm running a low velocity simulation yet I get an hypersonic velocity at the outlet…
Old   August 3, 2011, 09:44
BR
Lol...
Which version of OF are you using?
Old   August 3, 2011, 09:46
lore
OpenFoam 2.0.0
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 13:58
CFX does not continue Shafiul CFX 10 February 17, 2011 08:57
Proper Pressure Boundary Conditions for Buoyant Flow mchurchf OpenFOAM 0 March 25, 2010 13:16
Cell check and Boundary check errors AB Siemens 4 October 28, 2004 14:04
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
