Hardware selection for steady/unsteady incompressible, turbulent and cht simulations |
July 13, 2011, 04:52 |
maddalena
Rep Power: 23 |
I know that this question is posted every now and then on the forum, but... my hardware knowlege is so poor that I need a specialized answer... I am planning to buy a new workstation for my CFD simulations. I need some hints, some suggestions and some good advices on how to select it. Usually, I run steady, incompressible and turbulent simulations (simpleFoam), on really complex geometries (1 million cells at least). I would like to get into:
Here come my questions:
maddalena |
July 13, 2011, 06:12 |
Laurence R. McGlashan
Rep Power: 23 |
Really it will come down to "How much money do you have?".
When I built my workstation a few years ago I spent all the money (not much) on an Intel i7 with a good motherboard. Then put 6GB RAM in. That has worked well for me so far, although I tend to use "academic" meshes, so quite small! Better processors (look here http://www.intel.com/products/processor/index.htm) make your simulations faster and more RAM means you can run bigger simulations. To figure out how much RAM you might need, probably best to take some of your simulations, run them on different sized meshes and see how the usage changes, rather than listening to what others might tell you.
Laurence R. McGlashan :: Website |
July 13, 2011, 09:55 |
Olivier
Rep Power: 18 |
hello,
I would give the same answer as here :http://www.cfd-online.com/Forums/ope...tml#post315328 In short: go with 1 to 4 PC with core i5/i7, and do not go with workstation like dual xeon and Co. olivier |
cht, hardware, pimpledymfoam, simplefoam |
