yPlusRAS in pisoFOAM
Old   July 5, 2011, 08:25
Default yPlusRAS in pisoFOAM
Arina
Akuji is on a distinguished road
Send a message via ICQ to Akuji
Hello!
I had some troubles with calculating yplus. Well, I use OF-1.7.1, model is Spalart-Allmaras. In terminal after calculating pisoFoam I type yPlusRAS and for all my time steps I have the same result:
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model SpalartAllmaras
SpalartAllmarasCoeffs
sigmaNut 0.66666;
kappa 0.41;
Cb1 0.1355;
Cb2 0.622;
Cw2 0.3;
Cw3 2;
Cv1 7.1;
Cv2 5;
Patch 3 named ground y+ : min: 0 max: 0 average: 0
Patch 6 named nok y+ : min: 0 max: 0 average: 0
Writing yPlus to field yPlus
Why I have this result?
Akuji is offline   Reply With Quote
Old   July 5, 2011, 10:19
The True
Eren10 is on a distinguished road
did you specified any wall ?
Eren10 is offline   Reply With Quote
Old   July 5, 2011, 10:26
Arina
yes. As I understand, terminal saw my patches [walls]
Old   July 8, 2011, 05:26
Arina
Or maybe I should create a yPlusRAS file in folder 0 by myself?
Old   July 8, 2011, 07:05
The True
which files do you have at constant directory ?
I am using Kepsilon, and I just type yPlusRAS and it works.
Old   July 8, 2011, 08:17
Arina
In every directory I have files:
cellToRegion
nut
nuTilda
p
U
y
yPlus
(I use Spalart-Allmaras model).
In y file I saw a lot of numbers, but yPlus is similar to file nut (in structure)
Old   July 8, 2011, 08:53
The True
you dont need that files in every directory. at constant/ directory you should have transportProperties RASproperties .. and some of these kind files, check tutorials
Old   July 8, 2011, 08:57
Arina
I don't understand you first time. In /constant directory I ' ve got 3 files: RASPropeties, transportPropeties and turbulencePropeties. They are ok.
I may to attach them.
Old   July 8, 2011, 09:24
The True
You can check if yPlusRAS works on a tutorial that runs a turbulence model, try k-epsilon. and than compare your case with that, sorry I am also just a "user"
Old   August 31, 2011, 06:15
Default y+ without wall function
flowris is on a distinguished road
I have done simulations with kOmega SST and a wall function, and was able to calculate y+ using the command yPlusRAS.
However, now I want to do similar things, WITHOUT the wall function and integrating through the boundary layers. When I run yPlusRAS after the simulation, I get the message that I do not have a wall patch. I change this in the constant/polyMesh/boundary and I run the command again. Result: y-field can be calculated correctly, but there is still the complaint
    no nutWallFunction patches
What can I do? I don't have a nut wall function, but do I also have to change this in every time step after the simulation?
flowris is offline   Reply With Quote
Differences in solution method for pisoFoam and buoyantBoussinesqPisoFoam mchurchf OpenFOAM 7 August 6, 2023 10:12
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
Trouble migrating oodles to pisoFoam while changing from OF 1.5 to 1.7 sebi OpenFOAM 0 December 7, 2010 10:00
yPlusRAS with rhoTurbFoam fightingfalcon23 OpenFOAM Post-Processing 2 October 19, 2009 08:43
yPlusRAS in OF 1.6.x - Low Re Models ivan_cozza OpenFOAM Running, Solving & CFD 0 September 23, 2009 06:27
