July 3, 2011, 06:48 |
dual mesh
Nima Samkhaniani
Rep Power: 25 |
hi foamer
i have a general question! is it possible to have dual mesh in one geometry? i want to solve u and p in coarse grid and solve alpha in very fine grid to have very accurate interface, any hint? |
July 3, 2011, 12:47 |
You can do so with OpenFOAM. However, you havo to do fileld at different time step. When do the map, use meshToMesh class.
Regarding use two diffent meshes within one solver, just see the chtMultiRegionFoam solver. Regards, Junwei |
July 3, 2011, 20:57 |
Aidan
Rep Power: 16 |
From what you've said, I'm guessing you are using interFoam. Why not use interDyMFoam to adapt the mesh at the interface to keep it sharp?
July 4, 2011, 12:44 |
Nima Samkhaniani
Rep Power: 25 |
thank you! i have used interDyMFoam before hand, actually i used a modified version of interFoam with dynamic mesh which considers boiling, but as the interface is diffuse the number of cells get too high and it needs dynamic mesh refinement in every iteration which is time consuming! so i guess maybe there is a way to handle dual mesh simultaneously a coarse mesh for u and p and a finer mesh for alpha1
May 19, 2018, 07:59 |
krishna kant
Rep Power: 10 |
Hi nimasam
I am working on the same idea like yours in this thread. Curious to know whether you got success or not. Right now I am struggling with the interpolation thing between grids. I am using meshTomesh0.H |
coarse grid, dual mesh, fine grid |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
Meshing aifoil in ICEM | student123a | ANSYS Meshing & Geometry | 13 | December 8, 2010 11:40 |
mesh missing after export in gambit | morteza08 | ANSYS Meshing & Geometry | 1 | July 26, 2010 02:10 |
mesh missing after export in gambit | morteza08 | Main CFD Forum | 0 | July 23, 2010 03:19 |
