Polynomial thermophysical properties and laminar porous Zone
Old   June 28, 2011, 11:22
Default Polynomial thermophysical properties and laminar porous Zone
KKV
vemps is on a distinguished road
  • I am solving a simple exhaust system problem with porous domain. Want to avoid commercial Fluent software for simple problems.
  • Initially i solved the Problem using constant Cp value with sutherland viscosity. My pressure drop in the system slightly varies between OpenFoam rhoPorousMRFSimpleFoam and Fluent.
  • Fluent use Cp Polynomial varying with T, thermal conductivity polynomial varying with T, Laminar porous Zone, k and epsilon with intensity and hydraulic diameter.
  • I want to invoke similar criteria for the above parameters in Open Foam to get close match in pressure drop.
  • Can somebody please help me to give a detailed explanation or links as i am new to OpenFoam
  • How to give Cp and thermal conductivity polynomial ( i have gone through the modification of thermoType in one of the thread hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hPolynomialThermo<perfectGas>>>>>
  • Can somebody help me to give detailed procedure
  • How to give laminar Porous zone
  • What is the equivalent model in OpenFoam for k&epsilon of Fluent Intensity and hydraulic diameter. At present i am using k &epsilon of default properties specified in tutorial angledDuctImplicit
  • Sorry to give a long description. Please help me which will save lot of bugs for me to avoid commercial software for such problems
vemps is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
ReactingFoam Laminar flame simulation transport properties gbansal OpenFOAM Running, Solving & CFD 3 November 23, 2012 17:03
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Laminar diffusion flames and reactingFoam Transport properties jgaricano OpenFOAM Running, Solving & CFD 0 June 4, 2008 17:58
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
