simple 3D pipe flow diverges with icoFoam
Old   June 23, 2011, 10:24
Default simple 3D pipe flow diverges with icoFoam
Rol
Roland
Rol is on a distinguished road
Hello!
I am trying to get grips with OpenFoam. I set up a really EASY case. It is some kind of straight tube. The simulation should be easy, but after 6 iterations, icoFoam diverges. I use the solver settings from the elbow testcase.
Possible problems i thought on:
mesh: it is really fine, much too fine (just to be sure)
time step: is also set really small (dx=2/40 m, U=1m/s -> dt=0.05 should be sufficient, i set it to 0.01)
boundary conditions: inlet with Velocity set to 1 m/s; p at outlet set to 0 Pa. The rest is wall. I checked BC several times, and i find no mistake
I include the test case.
the case is ready to
blockMesh
and
icoFoam
you will see, it diverges after 6 time steps.
any hint is really appreciated!
Roland
Rol is offline   Reply With Quote
Old   June 23, 2011, 14:33
Rol
Roland
I think my test case was not as simple as i thought. The geometry of the tube leads to secondary flows. however, i found out convergence with upwind divScheme is much better.
Old   June 24, 2011, 10:55
mechy is on a distinguished road
I think the length of your tube in y direction is very small and you can not impose zeroGradient at the outlet I suggest you, to increase your length ten times of square root of section area
mechy is offline   Reply With Quote
Old   June 24, 2011, 13:03
Rol
Roland
mechy, thanks, although i checked the solver conditions several times i payed less attention on the geometry itself. It makes sense that the short tube interferes with the zeroGradient boundary condition. Thanks!
Old   June 25, 2011, 05:28
is your problem solved with increasing length of tube ?
Old   June 27, 2011, 18:02
Rol
Roland
yes, increasing the length solves the problem. Also i set the time step very low. maybe setting pressure boundary condition instead of velocity at inlet would also help convergence. but it works for me. thanks
Pipe flow with obstacle - HELP Min FLUENT 6 January 31, 2017 15:28
Disturbed flow field at outlet boundary (Multiphase flow through pipe) Michiel CFX 17 April 21, 2010 11:14
simple pipe flow question arkur CFX 1 July 11, 2008 17:32
Pressure Drop - Please Help - Simple Pipe Flow Joe A. FLUENT 2 April 23, 2007 08:50
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
