gas velocity looks weird in vicinity of inlet |
June 21, 2011, 06:33 |
Hi Foamers,
The gas velocity looks weird when i am doing simulations with solver twoPhaseEulerFoam. The inlet velocity of gas =1.2213 m/s and liquid=0.9214 m/s. However the gas velocity in in vicinity of inlet is always smaller than the one of liquid (gas velocity is larger than liquid velocity elsewhere, see figures). But if I look deep into the problem, I could see a large drag force to push gas bubbles but it failed to speed them up in those cells... I have to mention that here the drag force (on purpose of debug.) is calculated by the velocities (Ua and Ub) not as it is in the solver (where the drag force is calculated by the flux phia and phib). I have uploaded the case. BTW I am not quite sure about the setup of my pressure boundary conditions at inlet and at walls. I am still confused with BCs between zerogradient and buoyantpressure. Thanks // Kai Last edited by kaifu; June 21, 2011 at 11:11. |
VOF Volume fraction in Velocity inlet | aruelle | FLUENT | 2 | May 10, 2024 11:17 |
UDF inlet velocity profile mismatch with Fluent | ChristineL | Fluent UDF and Scheme Programming | 15 | November 25, 2016 07:45 |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 05:58 |
Gas velocity | Newbie | Main CFD Forum | 1 | April 7, 2003 06:55 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
