Numerical oscillations in LES due to mesh refinement
Old   June 14, 2011, 11:10
Default Numerical oscillations in LES due to mesh refinement
Martin Söder
Soder is on a distinguished road
Hi all,
I am doing LES simulation of the flow past inlet valves in engines.
And it seems like I get some kind of numerical oscillation at regions where the mesh has been refined.
I have tried both rhoPisoFoam and rhoPimpleFoam the problem is more apparent in rhoPimpleFoam (oscillations in both velocity and pressure) then in rhoPisoFoam (only oscillations in the near wall pressure)
I have tried different schemes and number of correctors with no significant improvement.
Does anyone have an idea what parameters I could check. The mesh is ok according to checkMesh aswell as for the software used to generate it (Fire)
I have attached som figures showing the oscillations aswell as the mesh.
The one showing velocity is rhoPimpleFoam
Best regards
Martin
Pressure fluctation at surface, rhoPisoFoam
Velocity fluctuations in rhoPimpleFoam
Soder is offline   Reply With Quote
les, mesh problem, oscillation
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 21:05
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
mesh refinement on top of existent mesh? jx FLUENT 10 January 11, 2004 05:32
