June 9, 2011, 12:39 |
parallel running openFoam-1.5-dev
luca
Rep Power: 15 |
hi everybody
I am running a 3d simulation of wave boundary layer flow around a cylinder over a flat bed. the domain has approximately 2 million cells. on a single processor is running without problems but when i run it in parallel it blows up. i am using a modified turbFoam solver and komega wilcox 2006 turbulence model. i am running other cases with the same solver without problems. Does anybody have an idea? cheers luca |
September 30, 2011, 14:11 |
Concordia_CFD
Rep Power: 16 |
Hi Luca,
what is the platform that you are running on? can you post your running script here? |
October 3, 2011, 05:24 |
luca
Rep Power: 15 |
Hi
I think the problem was simply that when running in parallel I was running for a much longer time period so my case would break anyway in the single processor running. How does it work? should I delete this thread??? |
October 3, 2011, 12:42 |
Concordia_CFD
Rep Power: 16 |
Hi, yes you could do so if you wish.
parallel |
running OpenFoam in parallel | vishwa | OpenFOAM Running, Solving & CFD | 22 | August 2, 2015 09:53 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Wall Function in OpenFOAM 1.5 dev | enry | OpenFOAM | 0 | March 3, 2010 07:14 |
[OpenFOAM] ParaView/ParaFoam in OpenFoam 1.5 dev | titio | ParaView | 2 | February 27, 2010 15:02 |
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev | titio | ParaView | 0 | December 9, 2009 13:13 |
