What software do you guys use for programming?
Old   June 7, 2011, 12:53
Default What software do you guys use for programming?
David Gaden
marupio is on a distinguished road
I'm curious - what works for you guys?
I'm only using gedit. Sometimes I want to search through the OpenFOAM code to find an example, but I can't easily do that. I wound up creating two massive files - one that contains all /src code, and one with /applications. Then I use gedit's search feature.
I recently learned about 'Ultraedit' (commercial), which would have made much of that easier... that got me wondering what other foamers do.
Open discussion welcome.
marupio is offline   Reply With Quote
Old   June 7, 2011, 13:33
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
I use gedit quite often with OpenFOAM, although I do use Eclipse a lot for other projects. Eclipse links in really well with CMake and Git so that you can do everything within the Eclipse IDE.
I think IDEs are especially useful when you start out (at least, new people in my group find code easier to get to know and navigate via an IDE).
I'm looking forward to the emacs/vi crew to pile in now.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   June 7, 2011, 14:08
Martin Beaudoin
mbeaudoin will become famous soon enough
Of course Emacs! Is there anything else?
Martin
mbeaudoin is offline   Reply With Quote
Old   June 7, 2011, 14:55
Assistant Moderator
Bernhard Gschaider
Yeah. XEmacs
Old   June 8, 2011, 04:25
akidess's Avatar
Anton Kidess
I use vim to edit code, grep to find in files and meld for diffs. Might be tough for beginners, but it works pretty well once you're used to it
Old   June 8, 2011, 07:44
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
You can also use 'git grep' or 'git grep --cached' for general searching. This can be useful independent of your editor.
olesen is offline   Reply With Quote
Old   June 9, 2011, 07:18
Arjun
arjun will become famous soon enougharjun will become famous soon enough
use notepad++, you will never use anything else after that.
arjun is offline   Reply With Quote
Old   June 9, 2011, 08:44
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
FYI, recently we release the first public version of gdbOF a tool to debug OpenFOAM attachable to gdb. It does easier to extract data formatting it to use Octave/Matlab, check BC's, dump matrices etc.
Check it out at: http://openfoamwiki.net/index.php/Contrib_gdbOF
Any new ideas o contributors are welcome!
Regards
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   June 9, 2011, 11:53
David Gaden
@Mark - grep - yeah, I've used it a little. I don't speak regexp very fluently... git grep would be useful if I used version control...
@Arjun - I use notepad++ on all my windows machines. I was looking for a version for Ubuntu.
@Santiago - I use gdb... a version that can make more sense of the objects in memory would be awesome! Thanks! I will check it out.
Old   June 9, 2011, 20:06
Arjun
i have started using it on ubuntu too. It works well with the help of wine. It is little bit hampered compared to windows version but still better than using gedit.
Install it with the help of wine and you will be able to run it.
Old   June 10, 2011, 08:55
Karl-Johan Nogenmyr
kalle is on a distinguished road
For small modifications I usually go with vi. For larger stuff gedit.
grep / find / diff are good friends too!
kalle is offline   Reply With Quote
Old   June 10, 2011, 13:46
Retired Super Moderator
Bruno Santos
I've had good experiences with Ultraedit in the past, but in Linux I usually resort to:
  • The most familiar to me as Ultraedit is Kate, which I use for massive editing and searching in files - I only use gedit if Kate is out of reach;
  • nano for quick editing;
  • and for some corner cases, I resort to: sed, find, grep, xargs, and some other bash/sh internal commands.
  • as for file comparison, diff or git diff, depending on the work layer.
[CAD formats] Hexahedral meshing of CAD files - Which free software? Wolle OpenFOAM Meshing & Mesh Conversion 14 November 22, 2014 22:40
Water mist modelling capabilities of any software. Iqbal FLUENT 0 January 13, 2011 03:59
CAD integrated CFD Software kostikr Main CFD Forum 3 February 4, 2010 15:38
Need help in proper CFD software AMusteykis Main CFD Forum 0 September 6, 2009 09:28
Visualization Software for CFD Paul Main CFD Forum 3 March 25, 2006 18:16
