Rep Power: 17 ![]() |
Hi everyone !
I would like to perform computations based on buoyantBoussinesqSimpleFoam and including radiation. I took a look at the buoyantSimpleRadiationFoam to check the radiation part in the energy equation. My problem is I don't see how to adapt the radiation contribution in the energy equation to the temperature equation of buoyantBoussinesqSimpleFoam. Did anyone already try to do so ? Or can anyone give me a hint on this ? thanks in advance. Fabien |
Markus Trompa
Rep Power: 13 ![]() |
Hello ayoros,
I am working on quite the same problem as you did. I want to implement radiation(only with view factors) in buoyantBoussinesqPimpleFoam but don't know exactly how to implement radiation terms in TEqn. Did you solve this problem? I am wondering because the calculation of Sh() for view factor is zero, do I have to handle with this stuff or can I use the normal bBPF solver? I would appreciate it if you could share your experience with me on this topic. Thanks in advance. Greetings Markus |
Does anybody has any solution for this?
Same problem here !
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
InterFoam with boussinesq approximation | sinusmontis | OpenFOAM Running, Solving & CFD | 2 | October 25, 2020 12:21 |
Boussinesq approximation, help please! | engahmed | FLUENT | 0 | May 20, 2010 11:25 |
Question on boussinesq approximation | panos_metal | FLUENT | 1 | January 11, 2010 11:18 |
boussinesq approximation | jamal | FLUENT | 2 | March 25, 2008 08:57 |
Boussinesq approximation again | Gabriel | Main CFD Forum | 3 | May 11, 2000 09:24 |
