SimpleFoam: Laminar vs. Turbulent Convergence
Old   June 2, 2011, 09:29
Default SimpleFoam: Laminar vs. Turbulent Convergence
Jason G.
JasonG is on a distinguished road
I have been experimenting with some test cases for internally bounded flow of a control valve manifold. Based on the geometry of certain passages, I have assumed that under a certain flow rate the flow regime should be laminar throughout the volume and turbulent above that value.
Utilizing the same mesh for all cases, I have successfully run the turbulent model (k-epsilon) on a test case that should yield turbulent flow in most regions. I have also successfully run the laminar model on a test case that should yield laminar flow in most regions. When I attempt to use the turbulent solver on the same laminar test case I start to get convergence then the solution crashes on me. I was initially thinking that the turbulent solver could be applied towards a laminar case, and the k,e, & nut variables would have a negligible contribution to the result. Is this an erroneous assumption, or is there possibly some other issues going on?
Just before the solver crashes, the two cases have a 0.9 psi difference in results.
JasonG is offline   Reply With Quote
Laminar field as initial state for turbulent two phase pipe flow kjetil OpenFOAM Running, Solving & CFD 3 July 21, 2009 10:15
Laminar Turbulence convergence Paul S. FLUENT 3 October 29, 2008 10:19
turbulent or laminar Novice FLUENT 1 October 8, 2008 10:39
Half laminar and turbulent model trying to solve Andrew Clarke FLUENT 5 May 19, 2008 14:40
turbulent & laminar result comparison quarkz Main CFD Forum 1 November 25, 2006 06:25
