Unstable Heat Flux
Old   May 25, 2011, 13:42
Default Unstable Heat Flux
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Hello everyone. I'm using a version of reactingFoam with an alternate formulation of chemistry and am investigating wall heat flux of strained diffusion flames. I am running turbulent cases using standard k-Epsilon and am finding that the wall heat flux keeps increasing even after the flame front has touched the wall.
I'm calculating heat flux using the same method as the wallHeatFlux post-processor. The thermal diffusivity looks about right near the wall, so I can't see what else might be causing problems. I've used this on laminar cases and haven't had any problems. Does anyone else had similar problems?
mturcios777 is offline   Reply With Quote
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 04:27
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 17:25
Variable name for heat flux peterle CFX 4 February 13, 2014 03:21
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 13:20
Heterogeneous heat flux Kev STAR-CD 4 July 7, 2009 05:48
