How to unit patches in the Boundary conditions |
May 25, 2011, 04:46 |
Rep Power: 15 |
hi,
im going to make heattranasfer investigation, as solver i want to use buoyantSimpleFoam. For that i want to use the existing "0"-folder from buoyantSimpleFoam. Now my problem is that the files in the folder for example for Temperature T only have 4 patches, and my part where i want to make my research have about 250 patches. And the patches from 3 to 180 have all the same Boundary conditions. So how i can put them together that i donīt have to write for each patch a line and define the Temperature. So my file now is looking like that: how can I unite the names which have the same temperature? Thank you, greets! /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 293; boundaryField { 1 { type zeroGradient; } 2 { type zeroGradient; } 3 { type fixedValue; value uniform 307.75; // 34.6 degC } 4 { type fixedValue; value uniform 307.75; // 34.6 degC } 5 { type fixedValue; value uniform 307.75; // 34.6 degC } : : : : from 6 to 179!!! : : : 180 { type fixedValue; value uniform 307.75; // 34.6 degC } 181 { type fixedValue; value uniform 307.75; // 34.6 degC } // ************************************************** *********************** // |
May 25, 2011, 05:05 |
Martin
Rep Power: 21 |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
natural convection | mehrdadeng | CFX | 10 | February 25, 2011 05:25 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
