Discretizer on Mac.
Old   May 25, 2011, 03:24
Default Discretizer on Mac.
paka is on a distinguished road
FYI. I couldn't find any information regarding Discretizer (http://www.discretizer.org/) running on Mac. I did download the source and played a little bit to try to make it work. Appears it runs well and fine on Mac. Below you can find a short guideline what to do in order to make it work:
1. Download the source:
http://www.discretizer.org/files/dis...7-12-01.tar.gz
2. Put the unpacked files into desired destination, i.e. /opt/
3. Add required Ruby libraries by running following commands:
- sudo gem install fxruby
- sudo gem install ruby-opengl
4. Get into the folder where you copied discretizer, i.e.: $DISCRETIZER_PATH/discretizer/
Inside the folder there should 'discretizer.rb' file. Open it and add in the list of all require calls (i.e. on top of them) following statement:
require 'rubygems' and save.
5. In the same folder run Discretizer by invoking:
ruby discretizer.rb
Hope it helps! Enjoy!
Krystian
Threads which were somewhat helpful in the process:
http://www.cfd-online.com/Forums/ope...scretizer.html
http://www.ruby-forum.com/topic/131049
http://www.discretizer.org/node/2
paka is offline   Reply With Quote
Old   June 3, 2011, 20:33
To get discretizerSetup running, do the following:
svn co http://fiscretizer.svn.sourceforge.n...r/discretizer/
then launch running: ruby discretizersetup.rb within discretizersetup/ folder.
Hope that helps. Best,
K
Extend Project 1.6-ext Binary Release for Mac OS X hjasak OpenFOAM Announcements from Other Sources 26 November 5, 2013 17:50
Caelinux discretizer front end to openfoam Thouelfaqar OpenFOAM 34 April 26, 2013 14:23
Discretizer questions be_inspired OpenFOAM 3 June 4, 2011 10:46
[Discretizer] Discretizer Rajshekar OpenFOAM Community Contributions 2 November 23, 2010 12:13
MAC + SOLA for free surface T Main CFD Forum 1 April 11, 2001 14:43
