mass fractions to mol fractions
Old   May 18, 2011, 11:21
Default mass fractions to mol fractions
Arun
arun is on a distinguished road
Hi All,
I simulating combustion simulation using dieselEngineFoam, and I would like to get the output of mol fractions of pollutants such as CO, CO2, HC, NO at every CAD. Currently I manage to get the mass of the species at every CAD.
E.g.
COAv << runTime.theta() << " " << fvc::domainIntegrate(composition.Y("CO")*rho).valu e() << endl;
Anyone can got any suggestion on how can I get the mol fractions?
Thanks in advance.
Regards
A
arun is offline   Reply With Quote
Old   May 18, 2011, 16:48
Default Mass to mole fractions
Adhiraj
adhiraj is on a distinguished road
I use OpenFOAM 1.7.1. As far as I see, you need to do the conversion yourself--possibly as a post processing step.
adhiraj is offline   Reply With Quote
Old   December 29, 2011, 15:58
saeed divrakhsh
valikiut is on a distinguished road
hello foamer
I want to simulate dual fuel diesel engine with OpenFOAM. Do I simulate this with dieselEngineFoam? If not, which solver I must use?
If I can use dieselEngineFoam, can I use (CH4) mass fraction in initial condition such as O2 and N2?
I want to calculate heat release rate (j/s), but in dieselEngineFoam output, dimension of dQ is (kg/(m^3*s)). How can I calculate heat release rate (j/s)? Do I have to change code?
Thanks.
Best Regards,
Divrakhsh
valikiut is offline   Reply With Quote
diesel combustion, dieselenginefoam, mol fractions, pollutants
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
fluent definitions for mass fractions perdita FLUENT 0 December 6, 2010 06:00
UDF for species mass fractions MRR FLUENT 0 December 29, 2005 08:14
Mole fractions from mass fractions? Keith Siemens 5 September 27, 2002 06:39
Changing inlet mass fractions of CH4 and O2 Prateep Chatterjee FLUENT 4 June 13, 2002 13:06
