about pEqn.H in bubbleFoam
Old   May 17, 2011, 10:39
Default about pEqn.H in bubbleFoam
Kai
kaifu is on a distinguished road
Hi Foamers,
The boundary condition of p in the tutorials of bubbleColumn (bubbleFoam) may be wrong. From
@ 0/p
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
    walls
        type            buoyantPressure;
        value           uniform 0;
@ constant/g
value           ( 0 -9.81 0 );
@ constant/polyMesh/blockMwshDict
vertices
    (0 0 0)
    (0.15 0 0)
    (0.15 1 0)
    (0 1 0)
    (0 0 0.1)
    (0.15 0 0.1)
    (0.15 1 0.1)
    (0 1 0.1)
patches
    patch inlet
        (1 5 4 0)
    patch outlet
        (3 7 6 2)
    wall walls
        (0 4 7 3)
        (2 6 5 1)
we may know the gravity is in -y direction, and the inlet and outlet are in xz plane (normal to y axis) while wall normal to x axis. Apparently it is a vertical pipe. So how could the zeroGradient BC applied to inlet and the buoyantPressure applied to walls? In my opinion, inlet should be applied to buoyantPressure BC while walls zeroGradient BC.
Another issue comes from
@pEqn.H
pEqn.setReference(pRefCell, pRefValue);
the pRefCell and pRefValue were defined in createFields.H as
    label pRefCell = 0;
    scalar pRefValue = 0.0;
    setRefCell(p, mesh.solutionDict().subDict("PISO"), pRefCell, pRefValue);
what do pRefCell and pRefValue mean? Since p refers to the "reference pressure" in all kinds of CFD generally, why do we need a pRefValue here? Do we make a reference for pressure reference once more here? In my case, the pressure at outlet is fixed at 0.
On the other hand, if we designate 0 for pRefCell, (it is no problem with serial computation), when it comes to parallel computation, will it be problem dependent? So far i have modified the bubbleFoam solver to my case, it works well with serial computation. But in the parallel computation, it shows,
GAMG: Solving for p, Initial residual = 0.0382384, Final residual = 9.98777e-11, No Iterations 767
in which the No Iterations is almost 30 times as it is in serial computation...
BTW i am using openfoam171.
// Kai
kaifu is offline   Reply With Quote
Old   September 12, 2013, 01:16
sam.ho is on a distinguished road
Hallo Foamers
I have the same problem and i would like to know the meaning of "pEqn.setReference(pRefCell, pRefValue);".
Could you please explain this line ?
Thanks a lot for your support
sam.ho is offline   Reply With Quote
about bounded alpha equation for bubbleFoam and twoPhaseEulerFoam kaifu OpenFOAM 2 May 6, 2011 06:33
using bubbleFOAM to model a sludge digester tank Franz_J OpenFOAM Running, Solving & CFD 1 September 30, 2010 23:09
Inputs for bubbleFoam rans2009 OpenFOAM 0 October 8, 2009 08:59
bubbleFoam rans2009 OpenFOAM 3 October 5, 2009 05:28
Lift force modeling in bubbleFoam holger_marschall OpenFOAM Running, Solving & CFD 2 December 10, 2007 16:24
