Search idea for solving a transient problem
Old   May 13, 2011, 04:36
Default Search idea for solving a transient problem
tH3f0rC3 is on a distinguished road
Hi there,
I need a good idea for solving a case transient.
The problem is that the case consists of about nearly 2 mio elements. And I need to solve 285 seconds transient.
The courant criteria calculated time steps from ~10^(-5) seconds.
Now I need a good idea how to solve the case transient.
What I still have tried:
- I still have reduced the element number from 9mio to 2mio elements.
- I have tried to run the case with a fixed time step 0.0001s, without success.
-> I have a question to that. If I choose to let the solver use the courant criteria for calculating the time steps, does the solver use constant time steps or can it be that sometimes he calculated a time step of deltat=10^(-5)s and sometimes deltat=10^(-3) seconds?
I want to know this because if the solver calculates the courant criteria only at time t=0 and uses than constant time steps, I think I can halve the time calculated by courant criteria. Because I think that the implementation of courant criteria in the solvers is configured conservative.
I think that on every time step the courant criteria is used to calculate the next time step, but I'm nut quite sure.
Maybe you need the information that I use chtMultiRegionFoam.
Best Regards,
tH3f0rC3
tH3f0rC3 is offline   Reply With Quote
Old   May 13, 2011, 06:45
Bernhard
Bernhard is on a distinguished road
You can easily see from the output of the solver, whether your timestep changes or not.
You can use adjustTimeStep in controlDict to recalculate the timestep based on the Courant number limit.
Bernhard is offline   Reply With Quote
Old   May 13, 2011, 11:22
Thanks for your answer, Bernhard,
so adjustTimeStep is for the recalculation after every time step?
So if I switch the setting to "no;" the courant number is only calculated at time t=0 and this time step is than used for every following time step?
Best Regards,
tH3f0rC3
Old   May 13, 2011, 16:01
Bernhard
If you set it to no, then the deltaT that you set in controlDict is used. The Courant number is only calculated, but not used later on.
Making a video from different snap shots of a Transient Problem Fascal FLUENT 1 December 22, 2010 07:19
Making a video from different snap shots of a Transient Problem Fascal FLUENT 0 December 19, 2010 02:03
time step and iterations in steady state problem using transient solver jing113cn FLUENT 2 January 15, 2010 04:18
transient heat transfer problem kamal FLUENT 2 June 29, 2008 15:55
transient problem run in steady state luigi FLUENT 4 March 13, 2008 07:54
