question to courant criterion
Old   May 12, 2011, 03:16
Default question to courant criterion
tH3f0rC3 is on a distinguished road
does someone know how the courant criterion is used in OpenFoam?
I'm using the chtMultiRegionFoam (transient-version).
Does the solver fit the time step according to the criterion? Thus, the time step isn't constant during the simulation?
Best Regards,
tH3f0rC3
tH3f0rC3 is offline   Reply With Quote
Old   May 12, 2011, 08:08
I have just recognized that it is possible to set the time step also to delta t = 0.1
Best Regards,
tH3f0rC3
Old   May 16, 2011, 03:22
can I use relaxationFactors for a transient solver like chtMultiRegionFoam?
I have read here that this doesn't work. But I don't understand why?
There is also mentioned that a simpletransient-Solver can work with relaxationFactors. But what is the transientsimple-Solver? Is this solver still calculating a transient case?
Best Regards,
Dirk
Old   May 16, 2011, 04:27
akidess's Avatar
Anton Kidess
Relaxation only applies to the SIMPLE algorithm, whereas most transient solvers in openFoam use PISO. A combination of both algorithms is called PIMPLE in openFoam.
Old   May 16, 2011, 04:58
thanks for your answer.
So can I set up the relaxationFactors in PIMPLE manually? Because you said PIMPLE is a combination of both algorithms.
Best Regards,
tH3f0rC3
Old   May 16, 2011, 05:27
akidess's Avatar
Anton Kidess
Yes, you should be able to specify the relaxation parameters in all SIMPLE and PIMPLE based solvers.
Old   May 16, 2011, 05:32
do you know if this is simply done by typing the following into the fvSolution-file?
relaxationFactors
   U   0.7;
   p   0.8;
Best Regards,
tH3f0rC3
Newbie Question IcoFoam - Courant Number explodes sprobst76 OpenFOAM Running, Solving & CFD 12 March 1, 2018 08:35
Courant Number Limit, CFL criterion barath.ezhilan OpenFOAM Running, Solving & CFD 2 September 24, 2010 08:48
Question on Courant no in userguide lakeat OpenFOAM Running, Solving & CFD 0 February 9, 2008 03:15
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
