Flointing point error also for a tutorial example
Old   May 9, 2011, 11:18
Default Flointing point error also for a tutorial example
cristina87 is on a distinguished road
I receive each time "Flointing point error" and I really don't know what to do anymore... I have to simulate a sandstorm - I tried to use the damBreak case from tutorials - I found another tutorial that develops this case - actually it changes only the geometry (it describes in blockMeshDict a bottle):
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2007/HassanHemida/Hassan_Hemida_VOF.pdf
I followed step by step what is there but when I apply the interFoam solver I receive tha Floining point error. For this tutorial I didn't change anything...
I worked before with another example - also begining from a tutorial (snowDrift example) and also I received the same error. I only changed the geometry and I generated other mesh.
Here are the last line from my output (first example with interFoam):
DICPCG: Solving for p_rgh, Initial residual = 0.853222, Final residual = 0.033701, No Iterations 20
time step continuity errors : sum local = 5.5888e-05, global = -8.29502e-06, cumulative = -0.0040989
DICPCG: Solving for p_rgh, Initial residual = 0.646448, Final residual = 0.0242661, No Iterations 27
time step continuity errors : sum local = 0.000127955, global = 4.05392e-05, cumulative = -0.00405836
DICPCG: Solving for p_rgh, Initial residual = 0.971427, Final residual = 7.87579e-08, No Iterations 260
time step continuity errors : sum local = 1.40968e-09, global = 4.77194e-13, cumulative = -0.00405836
ExecutionTime = 7.13 s ClockTime = 8 s
Courant Number mean: 0.205508 max: 417.869
Interface Courant Number mean: 0.000488175 max: 2.15027
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::Time::adjustDeltaT() in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::Time::setDeltaT(double) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so"
in "/opt/openfoam170/applications/bin/linuxGccDPOpt/interFoam"
#6 __libc_start_main in "/lib/libc.so.6"
I really don't know what do anymore - I'm beginer to OpenFoam and I tryed many ways - to redefine geometry, to refine the mesh and so on. I just want to make a very very simple example but I receive this error always.
Cristina
cristina87 is offline   Reply With Quote
Old   May 9, 2011, 11:24
Bernhard
Bernhard is on a distinguished road
Changes in the geometry can cause large differences in the physics and thus the results. Suppose you increase the size of the dam break case by a factor 100.
In your case the Courant number grows to large. This suggests to reduce the time step. (More info on Courant number can be found all around these forums)
Bernhard is offline   Reply With Quote
Old   May 9, 2011, 13:48
Andrea Pasquali
andrea.pasquali is on a distinguished road
Hi Cristina,
Did you calculate your Time step? It's max velocity e min cell size function. You can find the formula in OpenFOAM user guide.
Did you have those rows in your controlDict?
adjustTimeStep yes;
maxCo 0.9;
maxAlphaCo 0.5;
maxDeltaT 0.01;
They fix the Co and ensure you to run with the max time step allowable.
Andrea
Andrea Pasquali
andrea.pasquali is offline   Reply With Quote
Old   May 9, 2011, 13:59
I have so:
adjustTimeStep yes;
maxCo 0.5;
maxAlphaCo 0.5;
maxDeltaT 1;
and I receive Flointing point error. I set the maxCo to 0.2 and it worked...
I didn.t knowo about this formula ... Number of cells when I have:
"hex (3 2 1 0 17 16 15 14) (50 5 1) simpleGrading (1 1 1)"
is 50 x 5 x 1?
Cristina
Old   May 9, 2011, 15:33
Default After much time still error
Even with maxCo = 0.2 I receive this error but after much, much time:
Time = 0.0012026223658074956
MULES: Solving for alpha1
Liquid phase volume fraction = 0.00114771 Min(alpha1) = -4.86666e-05 Max(alpha1) = 1
Liquid phase volume fraction = 0.00114779 Min(alpha1) = -4.86559e-05 Max(alpha1) = 1
#2 Uninterpreted:
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam170/applications/bin/linuxGccDPOpt/interFoam"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam:perator/<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::tmp<Foam::GeometricField< double, Foam::fvsPatchField, Foam::surfaceMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libincompressibleTransportModels.so"
#6 Foam::fv::ddtScheme<Foam::Vector<double> >::fvcDdtPhiCoeff(Foam::GeometricField<Foam::Vecto r<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so"
#7 Foam::fv::EulerDdtScheme<Foam::Vector<double> >::fvcDdtPhiCorr(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libfiniteVolume.so"
#10 __libc_start_main in "/lib/libc.so.6"
#11
Floating point exception
Plot data for a fixed point aut_iut OpenFOAM 0 December 23, 2010 06:16
SI engine tutorial error non-positive volumes rackem FLUENT 12 November 22, 2010 09:06
Specify wall point Kr_kim OpenFOAM Running, Solving & CFD 0 February 12, 2010 16:53
UDF to define source term at every grid point Ralf Schmidt FLUENT 0 September 21, 2006 12:32
Track a flow parameter on a point Astozzia FLUENT 0 May 24, 2006 18:09
