April 24, 2011, 01:18 |
wmake error in Openfoam
Dhasthagheer
Rep Power: 15 |
Hi foamers,
I am new to openfoam. I downloaded my6DOFFoam solver from http://www.tfd.chalmers.se/~hani/kur...my6DOFFoam.tgz I tried wmake to compile this solver but I am getting following error cd my6DOFFoam wmake SOURCE=my6DOFFoam.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/transportModels -I/opt/openfoam171/src/transportModels/incompressible/lnInclude -I/opt/openfoam171/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam171/src/turbulenceModels/RAS -I/opt/openfoam171/src/turbulenceModels/RAS/incompressible/lnInclude -I/opt/openfoam171/src/finiteVolume/lnInclude -I/opt/openfoam171/src/dynamicMesh/lnInclude -I/opt/openfoam171/src/meshTools/lnInclude -I/opt/openfoam171/src/dynamicFvMesh/lnInclude -I/opt/openfoam171/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/my6DOFFoam.o my6DOFFoam.C:44: fatal error: incompressible/RASModel/RASModel.H: No such file or directory compilation terminated. make: *** [Make/linuxGccDPOpt/my6DOFFoam.o] Error 1 Thanks in advance |
April 24, 2011, 02:42 |
Nima Samkhaniani
Rep Power: 25 |
hi
i guess its about the conflicts between versions, it seems you use the latest version of openFOAM which some files of previous versions have been terminated! so use previous version for example 1.6 , it will solve ur probrlem, probably |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 09:48 |
Problems Installing OF 1.6 32 bit | bucksfan | OpenFOAM Installation | 19 | August 4, 2009 02:36 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 05:41 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 22:45 |
[OpenFOAM] ParaFoam error message | joey | ParaView | 1 | October 2, 2006 14:28 |
