CGNS Converter
Old   April 20, 2011, 09:18
Default CGNS Converter
Kurne
kurne is on a distinguished road
Dear All
I am trying to install CGNS converter and i have taken the repository from here
http://openfoamwiki.net/index.php/Sig_Turbomachinery_Utilities_CGNS_Converters
And as per the instruction given above i am trying to install CGNS converter but i am getting following error
make
cd . && /bin/bash /home/sameer/OpenFOAM/dear-1.5-dev/TurboMachinery/src/libcgnsoo_3.0/config/missing --run automake-1.11 --gnits
src/Makefile.am:31: Libtool library used but `LIBTOOL' is undefined
src/Makefile.am:31: The usual way to define `LIBTOOL' is to add `AC_PROG_LIBTOOL'
src/Makefile.am:31: to `configure.in' and run `aclocal' and `autoconf' again.
src/Makefile.am:31: If `AC_PROG_LIBTOOL' is in `configure.in', make sure
src/Makefile.am:31: its definition is in aclocal's search path.
make: *** [Makefile.in] Error 1
+ make install
+ popd
~/OpenFOAM/sameer-1.5-dev/TurboMachinery/src
+ wmake libso turboPerformance
The other utilities are working fine but the problem is with CGNS converter only.Can Anyone Help Me.
Thanks In Advance.
Simulation Is Determination Of Imagination Towards Approximation ®
Best Regards
Mubeen K Kurne
kurne is offline   Reply With Quote
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
CGNS unsteady dilemna smitha Main CFD Forum 0 February 16, 2011 10:13
Fluent 6.3.26 -> starCD 3.26.027 by using CGNS steph Siemens 1 April 3, 2008 17:14
Null Domain Pointer Error when importing CGNS mesh Matt FLUENT 2 November 26, 2005 02:01
develop CFD code based on CGNS vito Main CFD Forum 3 May 3, 2005 12:45
