April 20, 2011, 08:22 |
error message after use of wallheatflux
Rep Power: 15 |
does someone know the following error message: It occurs after I used wallheatflux or wallheatfluxlaminar after the use of the chtMultiRegionSimpleFoam solver. wallheatflux: Code:
Create time Create mesh for time = 0 Time = 0 Selecting thermodynamics package hPsiMixtureThermo<homogeneousMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> --> FOAM FATAL IO ERROR: size 914879 is not equal to the given value of 2282 file: /data/caehgb.za/studienarbeit-dirk/work/OpenFOAM/bertsche-1.7.1/run/Output_Ansa_to_OpenFoam/Ofenmodell/finish/restl.Ofen/stationaer/einfacherGalvano_ohnelayer/heat/testwallheatflux/0/p from line 18 to line 957627. From function Field<Type>::Field(const word& keyword, const dictionary&, const label) in file /local/OpenFOAM/src/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/Field.C at line 236. FOAM exiting Code:
--> FOAM FATAL IO ERROR: size 914879 is not equal to the given value of 2282 file: /data/caehgb.za/studienarbeit-dirk/work/OpenFOAM/bertsche-1.7.1/run/Output_Ansa_to_OpenFoam/Ofenmodell/finish/restl.Ofen/stationaer/einfacherGalvano_ohnelayer/heat/testwallheatflux/0/T from line 18 to line 933184. From function Field<Type>::Field(const word& keyword, const dictionary&, const label) in file /data/caehgb.za/studienarbeit-dirk/work/OpenFoam_ParaView/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/Field.C at line 236. FOAM exiting tH3f0rC3 |
April 20, 2011, 09:16 |
Wolfram Kretzschmar
Rep Power: 17 |
Hi!
As your error message reads "from line 18 to line 938934" or the like, maybe you forgot some closing brackets, some ";" or some needed values in the 0/p resp. 0/T files? Those files shouldn't be THAT large, don't you think? Cheers Wolle
CAELinux 2010 -- OpenFOAM 1.7 |
wallHeatFlux utility in OpenFoam1.6 | maruthamuthu_venkatraman | OpenFOAM | 29 | October 3, 2011 11:43 |
wallHeatFlux BC not constant after restart | eelcovv | OpenFOAM Running, Solving & CFD | 26 | May 25, 2011 00:11 |
wallHeatFlux for chtMultiRegionSimpleFoam? | af631717 | OpenFOAM Running, Solving & CFD | 0 | March 11, 2011 11:38 |
[swak4Foam] groovyBC + wallHeatFlux BC | prabhu | OpenFOAM Community Contributions | 1 | July 21, 2009 11:56 |
wallHeatFlux for heated walls in laminar channel flow | svens | OpenFOAM Post-Processing | 0 | June 20, 2009 21:33 |
