Heat Conduction in a Steady-State Open System |
April 18, 2011, 11:51 |
Rep Power: 15 |
Hello Fellow Foamers,
I am in need of some help. I am wanting to investigate the heat conduction in a steady-state open system, specifically within a nanosized vertical cylinder. My Case:
Any guidance would be much appreciated Thank you in advance, Jen |
April 19, 2011, 12:15 |
buoyantBoussinesqSimpleFoam
Fabian Roesler
Rep Power: 18 |
Hi Jen
Why do you use the compressible buoyantSimpleFoam? You could use the incompressible Boussinesq buoyant solver. There you don't have any problems with the pressure in your system as you just change the density in the gravity source term. With this solver you can have a closed system without volume change. Have a look at the tutorial. I am pretty sure you can use the total case except the geometry. It is a rectangular room heated from below. Regards Fabian |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 07:29 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 10:50 |
regarding steady state discrete phase calculations | hajszan_gyula | FLUENT | 1 | February 28, 2006 02:32 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 15:37 |
