April 18, 2011, 09:30 |
OpenFOAM LES: Averaging Velcoity
Rep Power: 15 |
In Openfoam for LES I know that you can implement a function in the controlDict file which calculates average velocity at each point based on all the time steps. If this is not implemented before the simulations begins, is there a way to do this now the simulation has finished ? FoamCalc perhaps? regards Ollie |
April 19, 2011, 05:16 |
Gregor Olenik
Rep Power: 17 |
Hi Ollie,
for run time averaging: have a look at the fieldAverage function http://foam.sourceforge.net/doc/Doxy....html#_details http://www.cfd-online.com/Forums/ope...ldaverage.html gregor PS: sorry i misunderstood your post. i am not aware of an existing post pro averaging tool. but writing your own shouldn't be too hard. Last edited by gregor; April 21, 2011 at 04:32. |
April 20, 2011, 08:05 |
David Aljure
Location: CTTC Universidad Politécnica de Catalunya. Spain
Rep Power: 15 |
Check this thread
http://www.cfd-online.com/Forums/ope...rocessing.html The only problem I found with this postaverage utility is it only uses the time data you saved, opposed to the fieldaverage function in run time that uses all timestep data. |
Reg. LES in OpenFOAM | ganeshv | OpenFOAM Running, Solving & CFD | 39 | February 26, 2014 21:07 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
Some questions about LES in OpenFoam | A.Devesa | OpenFOAM Running, Solving & CFD | 3 | July 26, 2010 09:35 |
Averaging LES | iko | FLUENT | 3 | July 3, 2008 06:55 |
Averaging Method for LES | Kim | Main CFD Forum | 0 | November 21, 2001 08:18 |
