Cyclic GGi
Like Tree2Likes
Old   November 15, 2019, 16:32
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Hojatollah,
I suggest you try the case in solids4Foam; maybe whatever the issue is, it has been fixed.
Kind regards,
Philip
bigphil is offline   Reply With Quote
Old   November 22, 2019, 05:51
Hojatollah Gholami
Hgholami is on a distinguished road
I also check the geometry with solids4Foam and the issue still exist. It seen the problem is from Ggi class.
the geometry is work correctly with cyclic condition but it can't run with cyclicGgi.
Originally Posted by bigphil View Post
Hi Hojatollah,
Kind regards,
Philip
Hgholami is offline   Reply With Quote
Old   November 22, 2019, 08:44
bigphil's Avatar
Philip Cardiff
Can you attach a small simple example case showing the problem?
Philip
Old   November 25, 2019, 15:14
Hojatollah Gholami
Dear Philip
the attachment is a simple case for foam-extend4.0 and solids4Foam solver.
http://uupload.ir/view/i0vb_simplecyclicggicase.zip/ fileSize:4.1 Mb
or
https://gofile.io/?c=XNJhb1
or
https://filebin.net/vstxf2bco1ts6xbd...zip?t=ag494xny
Philip
Old   November 26, 2019, 06:39
bigphil's Avatar
Philip Cardiff
In the case, you did not define the top and bottom patches as cyclicGgi in the polyMesh/boundary file (as described earlier in this post) e.g.
top
    type            cyclicGgi;
    nFaces          200;
    startFace       27345;
    shadowPatch     bottom;
    zone            topZone;
    bridgeOverlap   false;
    rotationAxis    (0 0 1);
    rotationAngle   0;
    separationOffset (0 -0.05 0);
bottom
    type            cyclicGgi;
    nFaces          200;
    startFace       27545;
    shadowPatch     top;
    zone            bottomZone;
    rotationAngle   0;
    separationOffset (0 0.05 0);
Once this is defined, the solver seems to run.
Philip
Old   November 26, 2019, 09:58
Hojatollah Gholami
Hi ,
In zip file, I modified polyMesh/boundary file by hand (without ./Allrun) as bellow:
inlet
type patch;
nFaces 50;
startFace 27295;
top
type cyclicGgi;
nFaces 200;
startFace 27345;
shadowPatch bottom;
zone topZone;
bridgeOverlap off; //or false
rotationAngle 0;
bottom
type cyclicGgi;
nFaces 200;
startFace 27545;
shadowPatch top;
zone bottomZone;
rotationAngle 0;
It seen same as your code, but my problem is
Time = 0.001, iteration: 1
Modes before clean-up : 0, modes after clean-up : 0
Current fsi under-relaxation factor: 0.05
Creating accumulated fluid interface displacement
Maximal accumulated displacement of interface points: 0
GAMG: Solving for cellMotionUx, Initial residual = 0, Final residual = 0, No Iterations 1
GAMG: Solving for cellMotionUy, Initial residual = 0, Final residual = 0, No Iterations 1
--> FOAM FATAL ERROR:
Attempting to create reconFaceCellCentres on a shadow
From function void ggiPolyPatch::calcReconFaceCellCentres() const
in file meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C at line 303.
FOAM aborting
Aborted (core dumped)
I don;t understand, where is problem? Is it work in your PC?
top
    type            cyclicGgi;
    nFaces          200;
    startFace       27345;
    shadowPatch     bottom;
    zone            topZone;
    rotationAngle   0;
bottom
    type            cyclicGgi;
    nFaces          200;
    startFace       27545;
    shadowPatch     top;
    zone            bottomZone;
    rotationAngle   0;
Philip
Old   November 26, 2019, 11:31
bigphil's Avatar
Philip Cardiff
OK, I didn't realise I should not use the Allrun script.
When I run it on my computer, it continues to run and does not give an error.
From examining the solution in the written time-steps, the inlet velocity condition does not seem correct (unlelated to cyclicGgi) so I then changed it to fixedValue with (3 0 0) and then the p and U fields looked reasonable.
I was using the development branch of solids4Foam (commit: 9b06f42) but I think the master should be almost the same, and foam-extend-4.0 (commit: 246a172c9).
Philip
Old   November 26, 2019, 15:39
Hojatollah Gholami
As you noted, I realize that the case study running continues in your computer without error. I checked the Turek&Hron benchmark with cyclicGgi in my PC and it work good. But for the case study, it take error in both fsiFoam and solids4Foam solvers.
I uses last solids4Foam in bitBucket. and the foam-extend-4.0 from https://github.com/Unofficial-Extend...oam-extend-4.0.
I think the problem comes from foam-extend's ggi but still confuse why in my PC. Can you give me your foam-extend-4.0 (commit: 246a172c9) for downloading and testing it?
Philip
Old   November 27, 2019, 07:31
bigphil's Avatar
Philip Cardiff
I was able to reproduce your error by using a more recent commit of foam-extend-4.0.
The foam-extend-4.0 commit that does not give an error (though I have not checked if the results are correct) is:
246a172c9d9ecdbfc8f18b8224467de7f2b7606e
A more recent foam-extend-4.0 commit that gives the error is: 10298020aac73b7f4b194c0369669c07325eb438
By using "git diff" to compare the commits (git diff 246a172c9d9ecdbfc8f18b8224467de7f2b7606e.. 10298020aac73b7f4b194c0369669c07325eb438 -- $FOAM_SRC), I can see that some code has changed in the GGI classes.
So I suggest one/both of the following:
  • Run your code in debug mode and through a debugger and find where the error is coming from i.e. what class; hopefully, this will tell where the problem is and how to fix it
  • Check that the older commit above works for you and compare the code between the two commits above and see if you can find what the problem is
Philip
Old   November 28, 2019, 06:27
Hojatollah Gholami
Dear Philip
Thanks for your reply.
I do your recommends. First I use debugSwitches for ggiInterpolation, ggi, cyclicggi, but It can't help me to recognize problem base. The attachment is log of it.
Second, I change src folder of my current foam-extend4.0 with src folder of commit 246a172c9d9ecdbfc8f18b8224467de7f2b7606e. But another error occur as:
Selecting physicsModel fluidSolidInteraction
Selecting fluidSolidInterface method IQNILS
Selecting fluidModel icoFluid
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
ggiPolyPatch::calcRemoteZoneAddressing() const for patch top
Initializing the GGI interpolator between master/shadow patches: top/bottom
From function void ggiPolyPatch::calcPatchToPatch() const
in file meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C at line 211
Calculating patch to patch interpolation for patchtop
Addressing already calculated
From function void GGIInterpolation<MasterPatch, SlavePatch>::calcAddressing() const
in file /home/itp/foam/foam-extend-4.0/src/foam/lnInclude/GGIInterpolationWeights.C at line 104.
FOAM aborting
This error also occur for Turek & Hron benchmark.
Old   December 12, 2019, 11:08
Thomas
hand90 is on a distinguished road
Hi everyone
This is probably going to be a very silly question but how do I define the faceZones?
I have imported a mesh of a 3D blade passage from ICEM with defined patches: Inlet, Outlet, Side1 (empty), Side2 (empty), SYM1 and SYM2.
Now I was able to run the simulation in a different OF version using cyclicAMI. However I am trying to use foam-extend 4.0 where I only have cyclicGgi available.
When the mesh is imported I have the following folders in polyMesh: boundary, cellZones, faces, faceZones, neighbour, owner, points,pointZones. Within the folder faceZones I do have 4 different zones, however they belong to different volume parts in the mesh and the periodic boundaries (SYM1 and SYM2) stretch through all zones.
Does anyone have a suggestion?
hand90 is offline   Reply With Quote
Old   December 12, 2019, 11:49
bigphil's Avatar
Philip Cardiff
You can use setSet and setsToZones.
Note: you may want to remove the old zones first i.e. rm -rf constant/polyMesh/faceZones.
Then use setSet and setsToZones:
$> setSet
readline>faceSet SYM1 new patchToFace SYM1
readline>faceSet SYM2 new patchToFace SYM2
readline>quit
$> setsToZones -noFlipMap
Philip
hand90 likes this.
Old   December 12, 2019, 12:46
Thomas
Dear Philip
This worked a perfectly. Thank you so much for that quick answer!
I applied that to two simulation setups I have (different mesh). In one it worked without an error and in the other simulation I got the following error:
Found uncovered faces for GGI interface SYM1/SYM2 while the bridgeOverlap option is not set in the boundary file.
This is an unrecoverable error. Aborting.
But by changing bridgeOverlap to "True" it was solved.
I am not fully sure why there seems to be uncovered faces as the simulation did run before hand with cyclicAMI.
Many thanks again
Old   December 13, 2019, 05:48
bigphil's Avatar
Philip Cardiff
The uncovered faces error says that your two cyclic patches do not fully overlap (to some built-in tolerance), possibly this could be due to an incorrectly prescribed transformation in the "boundary" file. Either way, it is a good idea to check the solution fields on both patches when you run your case to see if they are consistent.
hand90 likes this.
Old   February 5, 2020, 04:24
Hojatollah Gholami
Dear foamer
In previous problem, I checked a lot of commits, that not work correctly. In another try, I use DebugSwitches in controlDict
DebugSwitches
cyclicGgi 2;
ggi 2;
and write some Info in calcReconFaceCellCentres class.
The results show that, the solver selects correctly master patch as "top" and shadow patch as "bottom" and start running.
But after calculating pointMotionU, the calcReconFaceCellCentres class again called and after selecting top patch, go to selecting bottom patch. As the bottom patch isn't master, so the -->
FOAM FATAL ERROR:
occurs. As my test, it seen this problem usually appears in problem with more than a interface (should note: In fsiFoam, multiInterface merged as single Interface).
As the pointMotionU can't has boundary as cyclicGgi, so it defined as fixedValue; and If we use any others solver without calculating dynamic Motion is work correctly. So, it seen error comes from pointMotion. But how?
Ggi FabOr OpenFOAM 17 May 9, 2013 11:19
Cyclic vs ggi vs directMapped Patches jens_klostermann OpenFOAM Running, Solving & CFD 33 May 3, 2013 03:45
Difference between ggi and overlapGgi? GGI Tips and Tricks? philippose OpenFOAM Running, Solving & CFD 7 January 16, 2013 10:40
GGI in OpenFOAM-1.5-dev philippose OpenFOAM Running, Solving & CFD 14 November 13, 2011 15:55
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
