convertion of openfoam .msh file to fluent
Old   April 12, 2011, 12:43
Default convertion of openfoam .msh file to fluent
kostas
pankos is on a distinguished road
How can i convert the .msh file which used by openFOAM and which had made by gmsh mesh generator to FLUENT mesh input file. I have made some meshes in gmsh and i cannot input them to fluent.
pankos is offline   Reply With Quote
Old   April 13, 2011, 10:51
Fabio
Fabio_77 is on a distinguished road
foamMeshToFluent which converts the OpenFOAM
mesh into Fluent format and writes it out as a .msh file.
The resulting mesh is written out in a fluentInterface
subdirectory of the case directory,
i.e.<caseName>/fluentInterface/<caseName>.msh
Fabio_77 is offline   Reply With Quote
Old   April 14, 2011, 04:09
aaaaaaaaaaaaaa
panou is on a distinguished road
foamMeshToFluent is a simply converter or part of openfoam? where can i download it from? Can i run it by windows?
panou is offline   Reply With Quote
Old   April 14, 2011, 05:07
Fabio
foamMeshToFluent is a simply command in openFoam
Old   December 21, 2015, 13:30
Post foamMeshToFluent
Amr Refay
refay2006 is on a distinguished road
Hi Panou,
foamMeshToFluent is a command in OpenFOAM that will convert the meshing in OpenFOAM format to be in a meshing in Fluent format and it is a part from OpenFOAM.
You have to have OpenFOAM on your Linux system to run the command. You will need extra work on windows to install OpenFOAM and use the foamMeshToFluent command.
Thanks,
Amr,
refay2006 is offline   Reply With Quote
.msh file cann't be by Fluent nchuche FLUENT 1 June 29, 2010 11:38
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 18:33
The format of .msh file for fluent scubme FLUENT 2 October 18, 2004 23:50
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
