fluent3DMeshToFoam Error
Old   April 6, 2011, 06:52
Default fluent3DMeshToFoam Error
Kurne
kurne is on a distinguished road
Dear All
I am trying to convert the unstructured mesh generated in ICEM into OpenFOAM and while converting the mesh using utility fluent3DMeshToFoam i got the following error.One thing i want to add the size of fluent.msh is 409.1 MB.The error is
Create time
Dimension of grid: 3
Number of points: 1306895
PointGroup: 6 start: 0 end: 1306894. Reading points...done.
Number of cells: 4732963
CellGroup: 7 start: 0 end: 4732962 type: 1
Number of faces: 10257932
FaceGroup: 8 start: 0 end: 10087859. Reading mixed faces...done.
FaceGroup: 9 start: 10087860 end: 10113565. Reading mixed faces...done.
FaceGroup: 10 start: 10113566 end: 10255023. Reading uniform faces...done.
FaceGroup: 11 start: 10255024 end: 10257931. Reading mixed faces...done.
Zone: 7 name: BODY type: fluid. Reading zone data...done.
Zone: 8 name: int_BODY type: interior. Reading zone data...done.
Zone: 9 name: INTERFACE_VOLUTE_IMPELLER type: interface. Reading zone data...done.
Zone: 10 name: WALLS type: wall. Reading zone data...done.
Zone: 11 name: OUTLET type: outlet-vent. Reading zone data...done.
FINISHED LEXING
--> FOAM Warning :
From function boundBox::boundBox(const pointField& points)
in file meshes/boundBox/boundBox.C at line 68
Cannot find bounding box for zero sized pointField, returning zero
Creating patch 0 for zone: 9 name: INTERFACE_VOLUTE_IMPELLER type: interface
Creating patch 1 for zone: 10 name: WALLS type: wall
Creating patch 2 for zone: 11 name: OUTLET type: outlet-vent
Creating cellZone 0 name: BODY type: fluid
Creating faceZone 0 name: int_BODY type: interior
faceZone from Fluent indices: 0 to: 10087859 type: interior
new cannot satisfy memory request.
This does not necessarily mean you have run out of virtual memory.
It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library
Aborted
Will anybody help and i am waiting.
Thanks In Advance.
Simulation Is Determination Of Imagination Towards Approximation ®
Best Regards
Mubeen K Kurne
kurne is offline   Reply With Quote
Old   April 7, 2011, 05:25
Matthias Voß
mvoss is on a distinguished road
What is your memory peak during running the tool with this mesh?
"Cannot find bounding box for zero sized pointField, returning zero"
first thoughtid you export any empty field, faces from ICEM? You can simply check this by viewing the .msh-file in an text editor (even if this is VERY unusual).
second thought: reduce your meshdensities by ... 10 times, export, try the mesh-tool. Just to make sure the error is size-related.
mvoss is offline   Reply With Quote
Old   April 8, 2011, 07:17
sirLentschi
lentschi is on a distinguished road
Your abort is caused by a problem with your memory-size (ram). You need more memory to perfom the transformation.
lentschi is offline   Reply With Quote
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
user defined function cfduser CFX 0 April 29, 2006 11:58
