Constant pressure or constant volume combustion |
April 5, 2011, 10:17 |
Luigi
Rep Power: 15 |
I would to know if combustion occurs at constant pressure in ReactingFoam? I'm confused looking at the code, I don't understand the logical sequence in this model. 0(internalField: p0,T)0 -> reactions(therm_dat.chemkin.inp):Yi,Ti,hs -> GasPerfect: psi=1/RT -> basicPsiThermo(p const):rho=p*psi -> hmix=f(hs,psi) -> then how updates p at next time step...solving p equation???? which is the difference with rhoReactiongFoam? Please help me!Thanks |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 07:25 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 22:14 |
How to achieve constant static pressure in inlet? | Zou Jianfeng | FLUENT | 0 | October 21, 2008 02:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
