Error Message after wmake
Old   April 4, 2011, 09:29
Default Error Message after wmake
tH3f0rC3 is on a distinguished road
I want to "wmake" a downloaded file. The following error message appears after typing in wmake.
I have had the same problem by trying to change the name of a solver to edit the new one. During this procedure I also have to wmake the new file. The same error message appears.
...\>wmake
make: Warning: File `linux64GccDPOpt/options' has modification time 3.2e+02 s in the future
make: warning: Clock skew detected. Your build may be incomplete.
make: Warning: File `Make/linux64GccDPOpt/dontIncludeDeps' has modification time 3.2e+02 s in the future
Making dependency list for source file wallHeatFluxLaminar.C
make: Warning: File `wallHeatFluxLaminar.dep' has modification time 3.2e+02 s in the future
SOURCE=wallHeatFluxLaminar.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/data/caehgb.za/studienarbeit-dirk/work/OpenFoam_ParaView/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/data/caehgb.za/studienarbeit-dirk/work/OpenFoam_ParaView/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/data/caehgb.za/studienarbeit-dirk/work/OpenFoam_ParaView/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/wallHeatFluxLaminar.o
/var/tmp/ccpuUrrD.s: Assembler messages:
/var/tmp/ccpuUrrD.s:29272: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29273: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29274: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29275: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29276: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29277: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29278: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29279: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29280: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29281: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29282: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29283: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29284: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29285: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29286: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29287: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29288: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29289: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29290: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29291: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29292: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29293: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29294: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29295: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29296: Error: unknown pseudo-op: `.weakref'
/var/tmp/ccpuUrrD.s:29297: Error: unknown pseudo-op: `.weakref'
make: *** [Make/linux64GccDPOpt/wallHeatFluxLaminar.o] Error 1
Can someone tell me what I have to do?
I also have read this, but I'm not sure what to do now.
Regards,
Dirk
tH3f0rC3 is offline   Reply With Quote
Old   July 14, 2011, 18:20
Walter Schostak
wschosta is on a distinguished road
Hi, hopefully you've already resolved this but what you should do now is update to the newest version of Ubuntu or whatever OS you're using, update your compiler and then try running wmake again. If that doesn't work, try a clean install of OpenFOAM and then installing the solver again.
Best of luck if you haven't solved it, keep up the good work if you have!
wschosta is offline   Reply With Quote
Old   July 15, 2011, 02:22
I have installed OF on another faster computer. It has worked after this installation.
Best Regards,
tH3f0rC3
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 02:36
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 05:41
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 22:45
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 14:28
