What is the best solver used for modeling motion of the granular medium? |
April 2, 2011, 05:37 |
Shakir
Hi!
I've got a question: What is the best solver used for modeling motion of the granular medium? I mean bulk solids, such as sand or gravel. Is it possible with OpenFoam? Best regards Shakir. |
April 2, 2011, 11:09 |
lagrangian is the key word you are dealing with
http://www.openfoam.com/features/lagrangian.php |
April 4, 2011, 03:43 |
Robertas N.
Rep Power: 17 |
Another keyword: DEM (Discrete (Distinct) Element Method (Model)). There are some solvers meant specifically for this, e.g., YADE; and then there is LIGGGTHS, based on a molecular dynamics solver LAMMPS, coupled to OF to produce CFD-DEM.
Or you can kludge your own app for that, like I did some time ago... |
April 4, 2011, 07:51 |
Shakir
Hi r08n!
Thank you for replying me! I consider the granular medium as a non-Newtonian fluid. But I have no experience in writing their applications for OpenFOAM. I would be very grateful if you could send me your application and test case for studying! With best wishes Shakir |
October 30, 2011, 04:47 |
My Way of Calculation
Let me show you my way of calculating bulk solids behavier. You can find the theoretical discription (in German) and a small software programm under these links
https://skydrive.live.com/redir.aspx...OWbA8g6I5VU%24 https://skydrive.live.com/redir.aspx...QiQzxjHpXlM%24 Kind Regards ManfredH |
March 17, 2021, 03:26 |
YADE-OpenFOAM-coupling
Albrecht vBoetticher
Rep Power: 17 |
Hi i model debris flows and adapted the 4-way coupling of DPMFoam to my debris flow adapted version of interMixingFoam debrisInterMixing in debrisInterMixingLP- but to couple to large colliding particles that can do resolved CFD-DEM by clamping several particles together, the current best way is the coupling of YADE-OpenFOAM, https://yade-dem.org/doc/FoamCoupling.html
the interMixingFoam-DPMFoam based debrisInterMixingLP coupled well with YADE, based on YADE-OpenFOAM, only the limitations to stokes drag have to be extended to account for all particle forces and cell-dependent viscosity and density. |
bulk solids |
RBF motion solver does not work well in parallel | lakeat | OpenFOAM Bugs | 3 | August 8, 2013 05:50 |
interfacing a fluid solver with abaqus | Tuhin Rakshit | Main CFD Forum | 0 | June 16, 2005 10:03 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 16:49 |
Setting a B.C using UserFortran in 4.3 | tokai | CFX | 10 | July 17, 2001 16:25 |
Error during Solver | cfd guy | CFX | 4 | May 8, 2001 06:04 |
