Parallel
Old   March 28, 2011, 14:05
Default Parallel
longamon's Avatar
David Aljure
Location: CTTC Universidad Politécnica de Catalunya. Spain
longamon is on a distinguished road
Hi
I'm trying to run for the first time pisoFoam in parallel using three 2-cpu nodes of a infiniband cluster using openMPI, do I have to install OF in the 3 machines?
longamon is offline   Reply With Quote
Old   March 28, 2011, 19:43
Aidan
flowman is on a distinguished road
it will work if you install OF on all 3 machines. However, there is an easier method if you have a homogeneous cluster. Mount the OF directory from node 1 on node 2 and 3. This way you only need to install OF once on node 1
flowman is offline   Reply With Quote
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 23:51
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 07:17
Cumulative continuity error large in parallel simulations xiao OpenFOAM 3 March 7, 2011 05:13
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
