y+ and u+ values with low-Re RANS turbulence models: utility + testcase |
July 11, 2011, 06:55 |
#21 |
Florian Krause
Rep Power: 17 |
Hi grandgo,
if its a division by zero, then its definitely not in Code:
yPlus = y.y() * uTauAvg / RASModel->nu(); So division by zero happens then in Code:
uPlus = U / uTauAvg; Code:
U.boundaryField()[patchi].snGrad() Now, my question is, why is this? I dont know your case, but is it possible by any chance, that this is at time 0 and you initialize your internal velocity field as (0 0 0)? just a guess... Best, Florian |
July 11, 2011, 08:14 |
#22 | |||
Rep Power: 16 |
hi florian,
best regards grandgo |
July 11, 2011, 08:40 |
#23 |
Florian Krause
Rep Power: 17 |
Hi grandgo,
my understanding is, kinematic viscosity nu shouldn't be zero, since its a physical property, therefore nuEff is not zero. I also think that you should divide by nu and not nuEff even if its a LES case, see http://www.cfd-online.com/Wiki/Dimen...e_%28y_plus%29 and the source code of the yPlusLES utility. It really puzzles me where should be a division by zero if you comment out Code:
uPlus = U / uTauAvg; Is this the only case where you get the error message? Could you give me a small case where you get the same error message? Best, Florian |
July 11, 2011, 12:50 |
#24 | |
Rep Power: 16 |
i don't know why nuEff instead of nu is used in yPlusLES utility. i guess it makes no difference. and it's not the only case, where i get an error message. i picked the pitzDaily case in incompressible/pisoFoam/les and the same problem there. best, grandgo |
July 11, 2011, 14:50 |
#25 |
Florian Krause
Rep Power: 17 |
Thats weird! I just run the pitzDaily case a few second until t=0.017 (random) and used my own plusPostLES utility-it works!
Here are the relevant code snippets of my plusPostLES: Code:
int main(int argc, char *argv[]) { timeSelector::addOptions(); #include "setRootCase.H" # include "createTime.H" instantList timeDirs = timeSelector::select0(runTime, args); # include "createMesh.H" forAll(timeDirs, timeI) { runTime.setTime(timeDirs[timeI], timeI); Info<< "Time = " << runTime.timeName() << endl; fvMesh::readUpdateState state = mesh.readUpdate(); wallDist y(mesh, true); // Wall distance if (timeI == 0 || state != fvMesh::UNCHANGED) { Info<< "Calculating wall distance\n" << endl; Info<< "Writing wall distance to field " << y.name() << nl << endl; y.write(); } ... # include "createPhi.H" singlePhaseTransportModel laminarTransport(U, phi); autoPtr<incompressible::LESModel> sgsModel ( incompressible::LESModel::New(U, phi, laminarTransport) ); volScalarField::GeometricBoundaryField d = nearWallDist(mesh).y(); volScalarField nuEff = sgsModel->nuEff(); const fvPatchList& patches = mesh.boundary(); dimensionedScalar utauAvg("utauAvg", dimVelocity, 0); scalar nPatch = 0; forAll(patches, patchi) { const fvPatch& currPatch = patches[patchi]; if (typeid(currPatch) == typeid(wallFvPatch)) { yPlus.boundaryField()[patchi] = d[patchi] *sqrt ( sgsModel->nu().boundaryField()[patchi] *mag(UMean.boundaryField()[patchi].snGrad()) ) /sgsModel->nu().boundaryField()[patchi]; const scalarField& Yp = yPlus.boundaryField()[patchi]; uTau.boundaryField()[patchi] = sqrt ( sgsModel->nu() *mag(UMean.boundaryField()[patchi].snGrad()) ); const fvPatchScalarField& utauWall = uTau.boundaryField()[patchi]; dimensionedScalar utauTmp("utauTmp", dimVelocity, average(utauWall)); utauAvg += utauTmp; nPatch ++; Info<< "Patch " << patchi << " named " << currPatch.name() << " y+ : min: " << min(Yp) << " max: " << max(Yp) << " average: " << average(Yp) << " avgUMeanGradWall: " << average(mag(UMean.boundaryField()[patchi].snGrad())) << nl << endl; } } utauAvg /= nPatch; Info << "Avg. shear velocity is: " << utauAvg << "; # of walls: " << nPatch << "." << endl; yStar = y.y() * utauAvg / sgsModel->nu(); uStar = U / utauAvg; Sorry, at the moment there is nothing else coming to my mind what might cause the error. Regards, Florian |
July 11, 2011, 15:22 |
#26 | |
Rep Power: 16 |
why are you using UMean now? and what's Umean? and whats the difference between utauavg and utauavg.value() ? |
July 11, 2011, 16:41 |
#27 | ||
Florian Krause
Rep Power: 17 |
utauAvg += utauTmp; Regards, Florian |
July 11, 2011, 16:50 |
#28 | |
Rep Power: 16 |
Info << " avg. friction velocity uTau is: " << uTauAvg.value() << " (averaged over " << nPatch << " wall(s))" << nl <<endl; i don't know what the problem could be. i'm a newbie in c++ programming the utility would fit perfectly to what i need. i just go on trying and testing best grandgo |
July 11, 2011, 17:13 |
#29 | |
Florian Krause
Rep Power: 17 |
It is a class, would have to check the documentation for the exact definition... but think it comes from the generic dimensioned Type class dimensioned<Type> with member function value(). That means, if you only use uTauAvg it will output name, value and dimension. Even I am not a C++ expert... sorry again! |
July 13, 2011, 06:09 |
#30 |
Rep Power: 16 |
hi florian,
i'm struggling with the modification the thing is: i'm not changing much at all and it still doesn't work. here is what i changed in the createFields.H file: Code:
autoPtr<incompressible::LESModel> sgsModel ( incompressible::LESModel::New(U, phi, laminarTransport) ); that's all. the openfoam version is 1.7.1. i used the utility with the tutorial case: /incompressible/pisoFoam/les/pitzDaily, too. no chance. i dont understand this. EDIT: i think, my problem is history. these two lines in the modified utility caused the problems in my case: Code:
1) yPlus = y.y() * uTauAvg / nuEff; 2) uPlus = U / uTauAvg; the second line caused problems, because uTauAvg was zero at time = 0. as florian assumed, my 0/U internelField value is (0 0 0). so the solution is either to change the internalField value, or, as i did, change the code of the utility a little bit: Code:
timeSelector::addOptions(false, true); best grandgo Last edited by grandgo; July 13, 2011 at 13:15. |
November 17, 2011, 18:05 |
plusPostRANSUtitility for OF 2.0
#31 |
Jörn Nathan
Rep Power: 15 |
Hi *,
for converting the code of Florian to OF 2.0, "RASModel->nu()" had to be explicitely treated as "volScalarField&". The corrected code is attached. Have fun, Jona |
March 8, 2012, 06:28 |
#32 |
Elia Daniele
Rep Power: 16 |
Hi jona,
I've tried to build the utility as follow: :~/OpenFOAM/OpenFOAM-2.0.1/applications/utilities/postProcessing/wall/plusPostRANS$ wmake libso wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file plusPostRANS.C SOURCE=plusPostRANS.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/ag-peinke/OpenFOAM/OpenFOAM-2.1.0/src/meshTools/lnInclude -I/home/ag-peinke/OpenFOAM/OpenFOAM-2.1.0/src/transportModels -I/home/ag-peinke/OpenFOAM/OpenFOAM-2.1.0/src/turbulenceModels -I/home/ag-peinke/OpenFOAM/OpenFOAM-2.1.0/src/turbulenceModels/incompressible/RAS/RASModel -I/home/ag-peinke/OpenFOAM/OpenFOAM-2.1.0/src/turbulenceModels/incompressible/LES/LESModel -I/home/ag-peinke/OpenFOAM/OpenFOAM-2.1.0/src/turbulenceModels/LES/LESdeltas/lnInclude -I/home/ag-peinke/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/ag-peinke/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude -I/home/ag-peinke/OpenFOAM/OpenFOAM-2.1.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/plusPostRANS.o 'libNULL.so' is up to date. so it seems to be no error, but I should now use it it, since it doesn't work simply typing plusPostRANS in the case folder. Should I do something more??? Thanks for your help, Cheers, Elia |
March 8, 2012, 18:29 |
#33 |
Wouter van der Meer
Rep Power: 18 |
hello,
type wmake, not wmake libso hope this works Wouter |
March 9, 2012, 03:47 |
#34 |
Elia Daniele
Rep Power: 16 |
Hallo Wouter,
with the command "wmake" works as it should for compiling. Thanks very much. Elia |
April 16, 2012, 18:24 |
#35 |
Daniel P. Combest
Hello All,
First of all, thanks to Florian for making this, I have used some other yPlus utilities floating around here and this one was particularly interesting. I was attempting to get a uPlus and yPlus for something other than a pipe flow and I have been reading this thread thinking about the problem. Have made a modification to the plusPostRANSUtility utility provided (for OF 2.1.x) and I nearly get the same answer on Florian's test case (running pisoFoam) with my utility and his. However, it is (edit was) dreadfully slow since it searches for the nearest uTau over all wall faces for each cell. Right now it calculates a new y value (we will call it cellToFaceDistance), compares it to the current already calculated y value created using wallDist, and if there is a user specified fraction difference (i.e. (cellToFaceDistance-y)/cellToFaceDistance) than it is close enough and grabs that uTau for that cell and stops searching. I have uploaded the code to github and it can be downloaded with Code:
git clone git://github.com/chegdan/yPlusUplus.git EDIT: However, after thinking a bit...I'm not quite sure if this sort of u+ vs y+ is useful in cases where there is boundary layer separation around objects. For something where the streamlines are nice close to the object, it makes sense. For something with separation, it may not be best to non-dimensionalize the velocity field with respect to the friction velocity but the mean velocity. Either way, it was a good bit of code and if anyone can find it useful, enjoy. Cheers. Dan Last edited by chegdan; April 17, 2012 at 22:06. Reason: adding more detail |
April 21, 2012, 13:58 |
#36 |
Arnout
Rep Power: 16 |
Hi! Did you found the error. I get the same, nothing found yet...
June 11, 2012, 11:11 |
#37 | |
Eysteinn Helgason
Rep Power: 17 |
I have one question regarding your example case. I noticed that you use zero gradient for epsilon and nut at the wall. Can you ellaborate on why that is? (I somehow expected epsilon = 1e-9 or something small as you are solving for epsilon tilda and calculated for nut.) Best regards, Eysteinn |
July 24, 2012, 23:33 |
#38 |
Hi Jona and Florian,
Thanks for the utility I am sure it will help a lot of people. I am also interested in calculating the y+ for my case. But I have compressible simulation. I want to know two things: 1- If its a transient simulation shouldn't we use the mean values of U, rho and other variables? 2- How could I extend this utility to calculate the same numbers of compressible flow? Regards, Ali |
July 26, 2012, 09:42 |
Compressible y+
#39 |
I have made some small changes in the utility, developed by Florian/Jona. I have tried to make it work with compressible simulations. Please check it, if you see its working as it is supposed to work. Regards, Awais Ali P.S: For my case it reports a very low y+ values on the wall (unexpectedly). But the value that it writes seems to be Ok. |
August 13, 2012, 19:56 |
compressibleyPlusLES
#40 |
Hi All,
I have written this utility (again by modifying the utility previously developed) to calculate y+ and u+ values for compressible LES simulation. Please let me know if you find this utility working. For me its working fine. I have used on my own case. The yPlus values are as they were expected to be. Regards, Awais |
low-re rans, y* value, y+ value |
Low values of Lift force | vmlxb6 | CFX | 1 | February 2, 2011 06:13 |
Incompressible Turbulence models | achinta | OpenFOAM | 4 | May 27, 2010 11:35 |
turbulence models? | haider | FLUENT | 0 | March 8, 2006 00:58 |
Turbulence Models and external flow. | Alan | FLUENT | 3 | November 22, 2005 05:46 |
Turbulence boundary values | lego | CFX | 9 | October 25, 2002 12:55 |
