question about OpenFoam-temperatureGradient boundary condition
Old   March 24, 2011, 07:33
Default question about OpenFoam-temperatureGradient boundary condition
gulru
gulru is on a distinguished road
p { margin-bottom: 0.08in; } Hi all,
My problem is about applying temperature gradient to a wall in OpenFoam.
I have a rectangular box filled with gas and try to apply temperature gradient through the vertical axes. Therefore I put the fixedValue boundary condition for the up and down walls (for example 500C for up wall, 300c for down wall). But I don’t know how can I determined the boundary conditions for left and right walls.
How should I define the boundary conditions to obtain temperature gradient?
It maybe so simple question but I am new in OpenFoam. Therefore, I will be appreciate for any help.
p { margin-bottom: 0.08in; } Thank you very much....
gulru is offline   Reply With Quote
Old   March 24, 2011, 07:48
Bernhard
Bernhard is on a distinguished road
Did you try fixedGradient?
Bernhard is offline   Reply With Quote
Old   March 24, 2011, 12:50
gulru
p { margin-bottom: 0.08in; } Thank you very much for your help. Actually, I thought it but I could not understand how can I use .
I read something about the fixedGradient. At one of them it is mentioned that, fixed gradient evaluate data from internalfield. If I understand it right, internalfield should not be uniform for that case. It can be define as non-uniform, but I don't have data for defining non- uniform internalfield ( for non-uniform field definition, I should have some data about temperature for each position point). Therefore I couldn't decide about fixedgradient.
If you know how can i use fixed gradient boundary condition with internalfield, could you please help me?
Moreover I am also a little bit confused about gradient value defined for fixedgradient. I am not sure that manual entry for gradient value can represent the system correctly. Actually I thought that, the program does calculates the temperature value along the wall boundaries by using hot and low temperature given for up and down wall??
bounday conditions, temperature gradient
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
[Commercial meshers] Boundary condition problems (OpenFOAM) Milos OpenFOAM Meshing & Mesh Conversion 13 October 13, 2016 20:58
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 12:32
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 19:36
Question about the outlet boundary condition. G.H.Lee Main CFD Forum 5 April 29, 1999 05:50
