March 22, 2011, 14:06 |
compile ccm26ToFoam
Diego Villa
Rep Power: 16 |
Hi
I have a little problem, I have installed OF1.7.1 from the repository of Ubuntu. Now I must compile the ccm26ToFoam but it do not works. ----------------------------------------------------------------------------------------- diego@diego-desktop:~/Scrivania/OpenFOAM/diego-1.7.1/applications/ccm26ToFoam$ wmake SOURCE=ccm26ToFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/finiteVolume/lnInclude -I/opt/openfoam171/src/meshTools/lnInclude -I/opt/ThirdParty-1.7.1/libccmio-2.6.1 -I/opt/ThirdParty-1.7.1/libccmio-2.6.1/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/ccm26ToFoam.o ccm26ToFoam.C:46:19: error: ccmio.h: Nessun file o directory ccm26ToFoam.C:163: error: variable or field ‘CheckError’ declared void ccm26ToFoam.C:163: error: ‘CCMIOError’ was not declared in this scope ccm26ToFoam.C:163: error: expected primary-expression before ‘const’ make: *** [Make/linux64GccDPOpt/ccm26ToFoam.o] Errore 1 ------------------------------------------------------------------------------------------------ I need to install libccmio. Where I can find it? I haven't the ThirdParty directory. Thank a lot. Diego |
March 22, 2011, 18:32 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Diego,
I've personally reported that bug a few months ago and the fix for it is in the links in the bug report: http://www.openfoam.com/mantisbt/view.php?id=61 Best regards and good luck! Bruno
March 23, 2011, 11:37 |
Diego Villa
Rep Power: 16 |
Hi Bruno
Thank you very much! Now it works well! Diego |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 07:05 |
OF15 libccmio and thus ccm26ToFoam do not compile | henry | OpenFOAM Bugs | 29 | July 21, 2011 18:23 |
PV3FoamReader compile error.... | PEM_GUY | OpenFOAM Installation | 6 | April 5, 2010 18:22 |
Compile problem ccm26ToFoam in OpenFoam-1.6 | shildenbrand | OpenFOAM Bugs | 11 | October 20, 2009 16:43 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 22:51 |
