nutWallFunction
Like Tree26Likes
Old   March 13, 2015, 04:49
romant's Avatar
Roman Thiele
romant is on a distinguished road
When you take a look at the link that is posted with this explanation, you can see that the linear interpolation (which is the only one available in a CFD code) is used to insert the logarithmic form for the wall.
~roman
romant is offline   Reply With Quote
Old   March 13, 2015, 06:21
yusik
kimyusik is on a distinguished road
Originally Posted by EnricoA View Post
Hello romant,
I wanted to ask you why the velocity derivative used to compute the wall shear stress is approximated with a linear function, when the velocity distribution is known to be logaritmic. Don't you think that this lowers too much the accuracy of the simulation?
Regards,
Enrico
Dear Enrico,
Thanks for raising this question. I had the same question. In my opinion, the linear relation,
(mut+mu)du/dy = (mut+mu)Up/yP
is not valid in the log-region (y+>30). This relations is used in openfoam, the wiki (http://www.cfd-online.com/Wiki/Two_e...wall_functions) and also Bredberg, J. (2000), On the Wall Boundary Condition for Turbulence Models, Chalmers University of Technology Goteborg, Sweden.
The purpose of the wall modelling is to provide an appropriate skin friction where the velocity gradient cannot be calculated using a linear relation.
So I think
nu_t = nu*( kappa*yplus -1)
would be more reasonable instead of
nu_t = nu (yplus * kappa/ln(E*yplus) -1 )
for the standard wall function.
Please correct me if I am wrong.
Yusik
kimyusik is offline   Reply With Quote
Old   March 13, 2015, 10:20
romant's Avatar
Roman Thiele
Originally Posted by kimyusik View Post
Dear Enrico,
So I think
Yusik
It is true that in the log region, linearity cannot be used, however, you don't have any other values. Please take a look at Pope, Turbulent Flow, 2000, pp. 443, where the method on how to obtain this can be found.
Otherwise, there are some more threads in this forum (http://www.cfd-online.com/Forums/ope...tml#post484290) where you can find more about the implementation and why this is correct.
~roman
Old   January 16, 2020, 23:08
Jalil
Jalil786 is on a distinguished road
Originally Posted by kurne View Post
Dear All
Got the answer thanks to all.
Can you please share your experience how you solved the issue. I have the same problem. I don't know which wall function to use, what would be the value of Ks and Cs in the nut folder.
Thank you in advance!
Jalil786 is offline   Reply With Quote
second order schemes marine OpenFOAM 67 April 11, 2022 19:19
nutWallFunction vs. nutkWallFunction romant OpenFOAM Running, Solving & CFD 4 June 16, 2016 13:43
nutWallFunction questions madad2005 OpenFOAM 9 October 28, 2011 07:36
A few questions about Spalart Allmaras model and y seb62 OpenFOAM Running, Solving & CFD 8 January 15, 2011 14:09
nutWallFunction boundary condition AirS OpenFOAM Pre-Processing 6 March 3, 2010 08:31
