Gas Turbine combustor inlet boundary condtions
Old   March 3, 2011, 11:46
Default Gas Turbine combustor inlet boundary condtions
José Rodrigues
jose_rodrig is on a distinguished road
Hi all,
Im trying to simulate a gas turbine combustor for which I know inlet conditions (massflow, pressure, temperature) and I want to evaluate efficiency of the combustor based on the outlet conditions.
I have experienced that OF blows up whenever I specify at the inlet (fixedValue BC) either:
a) temperature pressure and velocity (T p U - fixedValue)
b) pressure and massflow (p phi - fixedValue)
c) pressure and velocity (p U - fixedValue)
The other quantities are set to zeroGradient (note for velocity also used pressureInletVelocity). FYI, im using reactingFoam which uses PISO solver for momentum equations.
This is a simulation for my master thesis, so I really need your precious help. Any suggestions?
Thx
jose_rodrig is offline   Reply With Quote
Old   March 3, 2011, 16:48
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi Jose
look here for inspiration
LINK TO THESIS
This is my master thesis, keep in mind we where very new to both CFD and OF moreso at the time. Also its using OF 1.4.1 but you should be able to get some inspiration.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   May 7, 2012, 02:17
Reza khodadadi
reza_65 is on a distinguished road
Send a message via ICQ to reza_65 Send a message via AIM to reza_65 Send a message via Yahoo to reza_65
Originally Posted by linnemann View Post
Hi Jose
LINK TO THESIS
Dear Niels Nielsen
could you please email your thesis for me? your link dose not work anymore
Email: Reza.khodadadi@modares.ac.ir
and
Could you please tell me, if your code, is for dynamic state of combustor?
And do you have ATEC code or any code that maybe I can use to simulate this model?
many regards
khodadadi.
reza_65 is offline   Reply With Quote
Old   May 18, 2012, 08:13
Default Helpp
juzer_700 is on a distinguished road
I have been trying to use ANSYS FLUENT Software to simulate cold flow analysis inside a combustion chamber. But I am having difficulties. It shows reverse flow when I run the calculation. My geometry is in 2D-Axisymmetrical. Also I have taken a swirl facter of 0.7 using K-Epsilon RNG turbulence method.
Inlet condition:
Velocity- 1m/s, Air at 600K
Pressure Outlet - Gauge pressure=0
Is the reverse flow because I have included the swirl in the flow? Or is it because my domain is small?
I would really appreciate if you can help me figure out the problem. Thanks in advance.
juzer_700 is offline   Reply With Quote
boundary conditions, combustion, gas turbine
3D Gas Turbine Combustor Ehsan Alborzi FLUENT 1 May 18, 2012 06:17
natural convection mehrdadeng CFX 10 February 25, 2011 06:25
Gas turbine load problem hashimbukhari Main CFD Forum 2 July 24, 2010 04:48
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
flow in gas turbine Abdul Hafid Main CFD Forum 1 September 14, 1998 10:39
