Git for openFoam 1.6-ext?
Old   March 2, 2011, 10:21
Default Git for openFoam 1.6-ext?
Peter_600 is on a distinguished road
Hi Foamers
Does for the 1.6-ext version exist something similiar as for the .x versions which keeps your OF always up to date, in other words compares ur actual OF 1.6-ext version with the lastest bug fix and if necerssary downloads the new files and recompile it ?
Apparently a a lot of bug fixes have been made since the latest release of 1.6-ext or do I have to wait for the next release?
Thanks in advance
Peter_600 is offline   Reply With Quote
Old   March 2, 2011, 12:25
Christian Lucas
Chris Lucas is on a distinguished road
Hi
git clone git://openfoam-extend.git.sourceforge.net/gitroot/openfoam-extend/OpenFOAM-1.6-ext
Regards,
Christian
Chris Lucas is offline   Reply With Quote
Old   March 2, 2011, 15:55
Thank you!
What do I need to do? Just use that command and it will compare my OF version with the latest one.
Peter
Old   March 2, 2011, 16:08
Thank you!
What do I need to do? Using that command and it will compare my OF version with the latest one.
Peter
Old   March 3, 2011, 03:43
Christian Lucas
use the command in the shell and it will download OF 1.6-ext. Also, the folder will be linked to the git repository and you can use the “git pull” (I guess) command to update OF.
However, I’m not sure if you can use your old OF 1.6 ext version for this update.
Regards,
Christian
k-omega-SST model (OF 1.6) - turbulent flat plate cboss OpenFOAM Running, Solving & CFD 25 August 9, 2016 10:53
GIT history OF 1.5 to 1.6 jackpap OpenFOAM 11 December 25, 2013 23:40
git installation of 1.6 romant OpenFOAM Installation 18 November 1, 2009 12:31
git svn clone of openfoam-extend Bost OpenFOAM 12 August 3, 2009 21:16
Installation Problem with GIT sega OpenFOAM Installation 2 May 8, 2009 09:46
